How to Calculate the Maximum Energy of Ejected Electrons?
Panic Attack
What is the maximum energy of the ejected electrons? When the radiation wavelength is 100 nm, and the stopping potential of the metal is 8.
KE = hc/wavelenght - Wo
I found the work function and the cut off wavelength to be the following but I can't figure out the max energy...
Wo = work function = { (6.63 *10^-34)(3*10^8) / (100 *10^9) } - (1.6*10^-19)(8)
Fo = cut off frequency = Wo / (6.63 *10^-34)
I think I have an answer, but I don't know if it is right...
E = Wo + KE, where Wo = 1.225*10^-19, in which I solved for
E = hc/lambda = 6.62*10^-34 * 3*10^8 / 150*10^-19 = 1.324*10^-18
E = Wo + KE
1.324*10^-18 = 1.225*10^-19 + KE
KE = 1.2015*10^-19?
Can someone tell me if this is right?
If it is not too late...
The max k.e. should be 8 eV
It's never too late. I think I got this problem wrong then. Can you explain how you got 8?
You are given wavelength and Wo in the problem statement, and are asked to calculate KE. You seem to be over-complicating things. (The answer is not 8 eV, by the way.)
teheheh... I got it right den... :)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
