How to calculate Toroidal Core Maximum VA capacity
66 replies · 29K views
jim hardy said:
multiple ?
tapped windings are done all the time
Just atop winding for moment, bring out a small loop in your secondary wire at however many turns you want, then continue winding
That loop becomes a tap.
http://www.bing.com/videos/search?q...8EEA92C1EEA1ECB69D6B8EEA92C1EEA1E&FORM=VRDGAR
hello hardy sir
I am winding center tap trafo of 35 0 35 using duel winding method(2 wire at same time ) ,if i want lower voltage from same winding can it possible ?
e.g for 25 0 25
e.g for 25 0 25
sure, bring out a tap at that number of turns
remember your turns ratio equation ?
230/755 = 25/X
X about 78 turns ?
did you ever figure out what is your flux density ?
SanPhysics said:
divide Webers by area of core in square meters to get Teslas
0.00137*0.001=1.37 Teslas.Is it right
sorry, i missed your earlier reply
from your first post
SanPhysics said:
Technical details of core OD-10cm, ID-6cm, height- 5cm
let's see
that gives for cross section 2cm difference in radius X 5 cm height = 10 square cm = 0.001 square meters
looks right to me !You must have a pretty good core there.
http://www.mag-inc.com/products/tape-wound-cores/typical-hysteresis-loops-for-tape-wound-cores
old jim
let's see
View attachment 104285old jim
Hello hardy sir
So my core is not saturate in 400 va use what's your thought .I think theas charts not for toroidal core (m4 crgo)
Hello hardy sir
Can it is compulsory to add thin copper strip on core between primary and secondary winding to avoid loss of magnatic flux. Because I can't find thin copper strip in my area .please help
it's probably not quite saturated at your 230 volts/755 turns.
The core has no idea what is amp load, just voltage.
no, they were a guess at what steel you might be usungm4 crgo hmmm
http://www.kryfs.com/knowledge-center/technical-papers/pdfs/article1.pdf
looks like you're about up to the knee
you should see some distortion from sine in the magnetizing current wave
from http://www.vikarsh.com/toroidal-cores.html
Comparative Chart
Toroidal core & C.T manufacturers need to know the B-H values of CRGO Materials after annealing over a wide range of Flux densities ranging from 100 Gauss to 19000 Gauss. We give below the actual values obtained on a core of size 150 mm OD x 100 mm ID x 25 mm HT with a stacking factor of 95% and a frequency of 50Hz.
....Tesla...M4..at/cm...23MOHgrade at/cm.. two other specialty cores...
no, that shield's purpose is not to contain magnetic flux, it's to remove effect of interwinding capacitance .
http://electrical-engineering-portal.com/purpose-of-shielded-isolation-transformer
I probably would forego the shield.
if you do add a shield be sure it doesn't form a closed loop or it will be a shorted secondary.
You could use very thin brass shim stock from an auto parts or machine tool store.
Even aluminum foil if you can figure how to connect to it.
SanPhysics said:
Thanks for reply
Hardy sir can you suggest any method to test output current of transformer so I can confirm that transformer is working properly .
What test equipment do you have available ?
if you can observe primary current waveform with an oscilloscope you should see effect of BH curve nonlinearity . The closer you are to the knee the more distorted will be the sine wave current.
If you have only a voltmeter and ammeter -
Check open circuit voltage to confirm turns ratio
measure output voltage with a resistive load to measure "regulation" Δvolts/Δamps , perhaps some large lamps, or a heating element perhaps a kitchen toaster or small electric heater.
hmmm i can't quite tell how you wound it
looks like you wound two wires ?
Here's your "start point"
do both wires go up over top and continue wrapping
or does left one go underneath ?
Next, verify
do you have two completely separate windings?
Place labels on your wires like this and find with ohmmeter which three are with each winding.
AND
that the two windings are indeed separate.
Then re-arrange your labels so that one winding has odd numbers 1(start), 3(25 tap), 5(35 finish)
and other winding has even 2(start), 4(25 tap), 6(35 finish) .
Verify again that even labels are on one winding and odd on other
Now energize your transformer and measure the voltages
1-5 (expected = 35V) measured = ? ____
1-3 (expected = 25V) measured = ? ___
3-5 (expected = 10V) measured = ? ___
2-6 (expected = 35V) measured = ? ____
2-4 (expected = 25V) measured = ? ____
4-6 (expected = 10V) measured = ? ____
Next, connect your two start wires 1 and 2 together
measure voltage 3 to 4 , I expect zero, what do you measure ? ____
measure voltage 5 to 6, I expect zero, what do you measure ? ____
If you get those readings try this
disconnect 1 from 2
connect 1 to 6 and use that for 0volt
voltage 1&6 to 5 ? (expected 35) __
voltage 1&6 to 2 ? (expected 35) __
voltage 1&6 to 3 ? (expected 25) __
voltage 1&6 to 4 ? (expected 10) __
voltage 5 to 2 ?... (expected 70) __
Might be we'll have to unwrap some turns and relocate one of the 25 volt taps...
old jim
Thanks hardy sir
Yes both wires go up over top and continue wrapping
Next, verify
AND
yes two winding is separate
old jim
All your suggestion is correct.And all result as you expected.
I am using only one tap at a time means 35-0-35 or 25-0-25 .so I don't have to unwrap turn.
Okay, there's our trouble
i didn't think about having to place the 25 volt tap 10 volts away from opposite ends of the two windings if they're wrapped same direction
That's one morelittle detail to be aware of, we will both do a better job of helping the next guy on that point...
If you want to you could add more turns to that 10 volt tap to get 25 volts, it'd work, just a minor "ugly" add-on.
On the positive side
you successfully wound that transformer without creating any shorted turns
and it behaves exactly as it should for how it was wound.
I call that a SUCCESS !
If you want to start a few more turns at your 10 volt tap and bring out a new 25 , you'll have a transformer that is functionally just what you wanted.
And - look how much we learned !
Congratulations on a nice job.
old jim
Hello Hardy sir
What are you doing
I got new toroidal core from my friend. He want wound power transformer for him.
Core size is OD-140mm, ID-90mm, Ht-50mm (M4 0.27mm CRGO) core wet about 3.3Kg.With my little knowledge an experience in transformer wounding I think
This core is more than 1000VA He want use this transformer of drive 500w audio amplifier. Is my gassing is right please replay soon.I will post core photo soon.
Try that link Anorlunda gave ?
http://www.brighthubengineering.com/diy-electronics-devices/96783-designing-your-own-transformer/
Your core cross section is (7.0-4.5) X 5.0 = 12.5 cm2, 1/800 m2
at 1 Tesla 50 hz it'd carry 100π X 1/800 = 0.39 volts per turn
so you'd need 230/0.39 = 589 turns at 230 volts
current for 1kva at 230 volts = 1000 /230 = a little over 4 amps, call it 5
#18 would carry that easily, #20 would probably work fine
window area is π X 4.52 = 63.6 cm2
and per anorlunda's link here's how many turns per square cm you can get with careful technique
at 60.8 turns per cm2 589 turns of #18 would take up 9.7 cm2, less than 1/6 of your window
looks to me like you have plenty of core there for 1 kva .
Which isn't surprising, the core has a window 1.5X bigger than your 418 VA core, and 418 X 1.52. = 940,
since it's also got 25% more cross section multiply by 1.25, 940 X 1.25 = 1175 .
Try your spreadsheet ? It seemed to work okay.
This time we'll remember to put the voltage taps close to the dotted end of their respective windings...
old jim
Hello dear hardy sir
Thanks for your useful thought
Can I don't have to consider stacking factor of core.
This table an my swg table on this link https://en.wikibooks.org/w/index.php?title=Engineering_Tables/Standard_Wire_Gauge&printable=yes
have very much different which table is right
#18 swg carry 3.7A with circular mil (750 kcmil/A) and 4.61A with (500kcmil/A) which circular mil have to consider.
And can I wound for more than 1.3 Tesla on this core.
hmmm after looking i find recommendations from 350 to 1000. I think i'd use 500, though 750 will run cooler.
Magnetics uses 500 for their inductor design example.
http://www.mag-inc.com/design/design-guides/Inductor-Design-with-Magnetics-Ferrite-Cores
4.61amps X 500 cmil/amp = 2305 circular mils which is closer to #16 per this table
http://www.mwswire.com/pdf_files/mws_tech_book/page4_5_6_33_34.pdf
so i stand corrected
your table gives turns per cm, how many adjacent turns will fit in a centimeter or inch, observe it's 1/diameter.
Turns per square cm or inch would be the square of that number
SanPhysics said:
And can I wound for more than 1.3 Tesla on this core. (M4 0.27mm CRGO)
What does the datasheet for the core say?
Suppose I use #17 gauge wire as per my table for primary winding so wire diameter is 1.42mm. so turn per cm2 is 10/1.42= 7.04, so 7.04*7.04=49 turn per cm2.
nearly 600 turn for primary. so 600/49=12.24cm2 window are required is it right sir.
no datasheet for core but manufacture test core with 10 turn and volt is 3.95.
i think so. It looks correct, with condition you won't get perfect lay on the wires so it'll usea kittke nore that 12.24 cm2
Have you tried your spreadsheet , the one you used for your transformer ?
0.395 volts per turn equates to how much flux ? 0.395 /100pi = 1.26milliwebers, in cross section of 1/800 m2 = only 1.006 Tesla RMS = 1.42 T peak.
See if you can find a recommended operating flux for that core, or stick with 1T rms..
Wow that'll be a challenging wind, manhandling 300+ turns of #12.
For 230 to 115 I'd look into buying one. Try a search on THG step down transformer to see what's available in your part of the world.
From your spreadshseet
great regulation,,
2.6 turns per volt = 0.385 volts/turn
0.385 / 100π = 1.22 milliwebers , in core area of 12.5 square cm
1.22 X10-3 W / 12.5 X 10-4m2 = 0.979 Tesla, should be safe for most transformer cores i'd think , it's 1.39T peak
Sanity check looks okay
losses at full load show around 35 watts primary , 75 secondary ,,, so at 2kva it'll run warm..
But i think it'll be a better transformer than you could buy . And you'll have fun.
keep us posted ?
Hello hardy sir
Thanks for your thought.
Sir how to calculate quickly both copper winding use how much mm redious of ID.Is that any formula.
What ? To figure power I used volts drop (from your spreadsheet) X amps at 2000VA, 2000/230 for primary and 2000/115 for secondary
i don't know what you are asking.
I mean How to find both primary and secondary magnet wire use how much Inner diameter (not area in cm2)of the core?
Hello hardy sir
Which adhesive i should use on bare core before start winding because core is old and have some rust on core.I have standard Epoxy adhesive pack which contain 2 small tubes one is resin and other is hardener.with mixing two same quantity both tube.I got jelly type transparent liquid.Can i apply this liquid on bare core its got hard in 40 to 60 minit.But I don't know it's uses for electrical purpose.
And can you suggest any insulating electrical tape for insulating primary and secondary winding like professional transformer use for their transformer.
here's 3M's selection.
http://multimedia.3m.com/mws/media/103938O/3m-oem-insulating-and-conductive-tapes-brochure.pdf
myself i use mostly Scotch 27 glass cloth tape but only because i had several rolls of it . I'd like to try their polyester.
How many layers of winding will you have ? What is thickness of wire ? Each layer will subtract that thickness from radius.
Rust on core ? You want to arrest that before you cover it. I would apply a phosphoric acid treatment .
.wikipedia.org/wiki/Phosphoric_acid said:
Rust removal
Phosphoric acid may be used to remove rust by direct application to rusted iron, steel tools, or other surfaces. The phosphoric acid changes the reddish-brown iron(III) oxide, Fe2O3 (rust) to ferric phosphate, FePO4. An empirical formula for this reaction is:
2 H3PO4 + Fe2O3 → 2 FePO4 + 3 H2O
Liquid phosphoric acid may be used for dipping, but phosphoric acid for rust removal is more often formulated as a gel. As a thick gel, it may be applied to sloping, vertical, or even overhead surfaces. Different phosphoric acid gel formulations are sold as "rust removers" or "rust killers". Multiple applications of phosphoric acid may be required to remove all rust. Rust may also be removed via phosphate conversion coating. This process can leave a black phosphate coating that provides moderate corrosion resistance (such protection is also provided by the superficially similar Parkerizing and blued electrochemical conversion coating processes).
It's in hardware stores as Naval Jelly or Ospho. It turns the rust black . Then apply your epoxy. I've never had rust eat through paint when i Ospho'd the metal before painting.
Of course, wire brush or steel wool the loose rust away, and get it thoroughly dry before applying paint or epoxy.. I put my treated parts in the oven on "warm".
Hello San,
If I already have the transformer ready then how can I calculate the effective area Ac of the core?
My core Dimension are OD=80mm, ID=46mm H=30mm, 100VA
VA=5.0*J*Bm*f*Ac min*ID²*10-7
