Helena17
- 6
Hello,
I have made an experimental work and I am ask to provide a formal experimental error analysis. I have a difficulty to choose the appropriate analysis way and would like to have some advices or explanations.
I have measured a temperatures at the intlet (Ti) and outlet (To) of a heat exchanger and the mass flow rate of the fluid. I can calculate the power:
Q = mC (To-Ti)
From what I learn on uncertainty calculations, I am a little bit confused. I finally found that I could calculate my uncertainty in two ways:
(1): \frac{ΔQ}{Q} = \frac{Δm}{m}+ \frac{2ΔT}{To-Ti}
(2): \frac{ΔQ}{Q} =\sqrt{\left(\frac{Δm}{m}\right)^2+\left(\frac{2ΔT}{To-Ti}\right)^2}
Δm: accuracy of the mass flowrate meter (documentation of the supplier)
ΔT: accuracy of the mass flowrate meter (value given by the calibration center)
C is admit as a constant
I made just one measurement. Which one of the above equations must I use and why?
Actually, I derived heat transfer coefficients (built a curve) from several measurements, by changing the flowrate m and the inlet temperature Ti. But no test has been repeated in the same conditions. Is the first method or the second one am I going to use for the "error analysis"?
Thank you in advance.
P.S. Please, even if you do not have a time, even a short answer would be useful for me.
Q = mC (To-Ti)
