How to control heavy ball in x and y direction?
To control the movement of a heavy ball in both X and Y directions, the setup involves two motors and rubber bands attached to black cylinders. Concerns arise about friction between the ball and the rubber, especially if only one motor operates, which could hinder movement. Suggestions include positioning rollers farther from the ball's center to enhance stability and reduce friction. The design resembles a computer mouse with a ball, but the weight distribution poses challenges. An alternative concept is a motorized floating ball fountain, which could provide a smoother movement mechanism.
_Patrick_
Hi there - I'm trying to build a decorational device that holds a rather heavy ball and I want to be able to control it's "movement/roll" in the X and Y directions (they are horizontal as well as orthogonal).
The two black cylinders (X and Y) aren't floating, but I forgot to draw their support pillars. They are wrapped into a rubber band each, which both are attached to two differrent motors in order to make them rotate.
The support is just an attempt to not drop the ball and is placed "behind" it from our point of view.
I have 2 questions:
1) If only the X-motor runs, will there be such a great friction between the ball and the Y-rubber that this configuration won't work?
2) Do you have any other ideas where the motion will come from external motors and rubber bans?
Welcome to PF, Patrick.
Your questions confuse me a bit, and I'm no expert in the matter anyhow, but I have one suggestion which might be an answer to #1. If you place your rollers farther out around the circumference of the ball, you will lower its centre of gravity and thus make the system more stable.
Hard to say but in principle, yes. There is definitely a lot of friction here.
Your device is identical to the computer mouse with a ball configuration. Two rollers at 90 degrees with a 3rd for support. However, yours is upside down from a mouse. That means all the weight of your ball rests on the rollers. With a heavy ball and rubber rollers, you will definitely have a lot of problems with friction.
Would something like this work?
You could do something similar to a floating granite ball fountain, but with motorized wheels to spin it in the needed directions.
http://www.hydrodramatics.com/floating_granite_ball_fountains.htm
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
