How to convert 1 frequency to a lower frequency?
In summary, the hardware needed to convert a radio signal at 5.8 gigahertz to a radio signal at 100 megahertz includes a receiver for 5.8 GHz, a digital data recorder, and a transmitter for 100 MHz. This conversion is achieved through a process called heterodyne action, which involves mixing the 5.8 GHz signal with a locally generated CW signal at 5.7 or 5.9 GHz. The resulting outputs at sum and difference frequencies are then filtered to isolate the desired frequency of 100 MHz. This process requires a non-linear device, such as a square law diode, and a local oscillator circuit to generate the CW signal. Another option is to demodulate the
David lopez
257
could you describe the hardware needed to convert 5.8 gigahertz to 100 megahertz?
i mean could you describe the hardware needed to convert a radio signal at 5.8 gigahertz to a radio signal at 100 megahertz? the hardware receives a radio signal at 5.8 gigahertz and retransmits it at 100 megahertz.
Receiver 5.8 Ghz, Digital data recorder, Transmitter 100 Mhz
Likes russ_watters
but, how does it convert the higher frequency radio signal to the lower frequency radio signal?
The usual method is to mix the 5.8 GHz with a locally generated CW signal at 5.7 or 5.9 Ghz. This produces a beating action and creates outputs at sum and difference frequencies. We filter off the wanted one at 100MHz and amplify it to the desired power.
The process is called heterodyne action, and the mixer must be a non linear device, such as a square law diode. We usually amplify the 5.8GHz a little before the mixer in order to overcome mixer losses and noise. The circuit producing the CW signal for the mixer is called a local oscillator.
Likes Keith_McClary and trurle
Yes, the alternative is to demodulate the 5.8GHz signal and then re-modulate the information on to a 100MHz carrier.
Likes skeptic2 and berkeman
Depending on the type of signal or data you plan on sending you may have buffering issues. Keep in mind data rate is basically dependent on carrier frequency, well, data rate is dependent on bandwidth, but the bandwidth cannot be higher than the carrier, so carrier freq puts an upper limit on data rate. The 5.8GHz would have a much higher data rate potential than the 100MHz, just something to be aware of.
Here's another wide open question from you. What have you actually read about this? Search Google for frequency mixing and heterodyne circuits and ask a question about something you have actually found out on your own.
Likes davenn, Vanadium 50 and Averagesupernova
1. What is the formula for converting 1 frequency to a lower frequency?
The formula for converting 1 frequency to a lower frequency is: New frequency = Original frequency / Desired frequency ratio. This means that you need to divide the original frequency by the desired frequency ratio to get the new frequency.
2. How do I determine the desired frequency ratio?
The desired frequency ratio can be determined by dividing the original frequency by the new frequency. For example, if the original frequency is 100 Hz and you want to convert it to 50 Hz, the desired frequency ratio would be 100/50 = 2.
3. Can I convert any frequency to a lower frequency?
Yes, you can convert any frequency to a lower frequency as long as you know the original frequency and the desired frequency ratio.
4. Is there a limit to how much I can lower a frequency?
There is no limit to how much you can lower a frequency. However, the lower the desired frequency, the more difficult it may be to achieve a precise conversion due to limitations in equipment and technology.
5. Are there any other methods for converting 1 frequency to a lower frequency?
Yes, there are other methods for converting frequencies, such as using a frequency mixer or a frequency divider. These methods may be more complex and require specialized equipment, but they can also provide more precise conversions.
  • Electrical Engineering
