How to create a uniformly charged sphere?
The discussion revolves around the feasibility of creating uniformly charged spheres and spherical shells in a laboratory setting. Participants explore various configurations, including uniformly charged spherical shells of finite thickness and radially symmetric charge distributions, while addressing theoretical and practical considerations.
  • Some participants suggest charging a spherical shell by placing charge on an isolated conducting sphere.
  • Questions arise about whether an isolated conducting sphere needs to be inside a spherical shell to achieve a uniformly charged shell of finite thickness.
  • It is noted that charge on a conducting sphere will uniformly spread on its surface from a macroscopic perspective, though microscopically, the surface may not be smooth.
  • Participants discuss the concept of radially symmetric charge distributions and whether such distributions can be achieved with finite thickness shells.
  • One participant points out that an uncharged spherical shell trivially has a radially symmetric charge distribution.
  • Clarifications are sought on the meaning of "radially symmetric charge distribution," with some equating it to "spherically symmetric."
  • There is a discussion about the uniqueness of solutions to Poisson's equation under certain boundary conditions, implying that spherical symmetry requires specific forms for potential and charge density.
  • One participant summarizes that no viable methods have been suggested for creating uniformly charged spheres or shells, while noting that quasi-static charge distributions can occur in dynamic situations.
  • Examples of dynamic charge distributions are provided, such as those in plasma balls and configurations involving current flow between electrodes.
  • A suggestion is made to plate charged conducting and insulating shells on a spherical pellet, though its practicality is questioned.
Participants express multiple competing views regarding the creation of uniformly charged spheres and shells, with no consensus reached on viable methods. The discussion remains unresolved on how to achieve static charge distributions over finite volumes.
Participants acknowledge limitations in achieving uniformly charged configurations and the dependence on specific conditions and definitions related to charge distributions.
oliverkahn
Can we create at least any one of the following in laboratory? How?
1. A uniformly charged spherical shell of finite thickness
2. A uniformly charged sphere
3. A radially symmetrically charged spherical shell of finite thickness
4. A radially symmetrically charged sphere
The only thing I can imagine is to charge uniformly a spherical shell by just putting some charge on an isolated conducting sphere.
Will putting some charge on an isolated conducting sphere will make a spherical shell of finite thickness uniformly charged? Should the isolated conducting sphere needs to be inside the spherical shell of finite thickness?
The charge put on the sphere will uniformly spread on its surface (from a macroscopic point of view only of course; microscopically there's not smooth sphere to begin with).
Macroscopically, is there a way, at least, to make a spherical shell of finite thickness radially symmetrically charged?
An uncharged spherical shell of finite thickness has, trivially, a radially symmetric charge distribution.
A charged conducting spherical shell of finite thickness has a radially symmetric charge distribution with the unbalanced charge on a shell of infinitesimal thickness.
Your desire is for the charge density to be finite and non-zero throughout the volume of the spherical shell?
Can you explain why?
Well, what do you mean by a "radially symmetric charge distribution"?
I understand the term to be a synonym for "spherically symmetric" -- i.e. that the charge density at any point on a spherical shell of radius r is the same as at any other point on that shell.
Sorry, my connection was down.
Yes, I mean charge density at radius ##r## is constant
A zero charge density everywhere is the same everywhere.
No... I am talking about all radially symmetric charge distributions except that.
It cannot be zero for every ##r##.
oliverkahn said:
No... I am talking about all charge distributions except that.
Then a charged conducting sphere does the job, right?
1) Why does a charged conducting sphere has radially symmetric charge distribution?
2) Or do you mean by placing a charged conducting sphere inside a spherical shell of finite thickness, the shell acquires radially symmetric charge distribution? Why?
The solution of Poisson's equation with appropriate boundary conditions is unique.
If you want spherical symmetry both the potential and the charge density must be functions of ##r## (in spherical coordinates only).
Thus 1) implies you have the solution
$$\phi(r)=\begin{cases} \frac{q}{4 \pi a} & \text{for} \quad r<a,\\
\frac{q}{4 \pi r} & \text{for} \quad r \geq a. \end{cases}$$
The charge distribution is
$$\rho=-\Delta \phi(r)=-\frac{1}{r} \partial_r^2 (r \phi) =-\frac{q}{4 \pi a r} \partial_r \Theta(a-r)=\frac{q}{4 \pi a^2} \delta(r-a). $$
This is a surface-charge distribution, ##\sigma=q/(4 \pi a^2)=\text{const}## along the sphere.
2) is somewhat more complicated. Let again ##a## be the radius of the inner conducting sphere and ##b## and ##c## the inner and outer radius of the shell of finite thickness, ##a<b<c##. For ##r<b## you have of course the same solution as above. Then you have
$$\phi(r)=\frac{q}{4 \pi} \begin{cases} 1/a & \text{for} \quad r < a, \\ 1/r & \text{for} \quad a \leq r<b, \\ 1/b & \text{for} \quad b \leq r<c, \\ 1/r & \text{for} \quad c \leq r. \end{cases}$$
You can calculate and interpret the various surface chrages on the surfaces of the conductors yourself!
To summarize, I believe no one has suggested a way to do 1, 2, or 3. The only solution suggested for 4 is a charged conducting sphere where the charge will be uniformly distributed on the outer surface. The charge shell is effectively infinite thin, so this isn’t anything like what you asked for in 1-3, but you have to admit it is radially symmetric, and so technically a valid example that fits your #4 request (even if that isn’t what you meant to ask for)
In short, we haven’t helped much. I can’t think of a way to get a static charge distributed over a finite volume.
However, you do get quasi-static distributions of charge over volumes in dynamic situations, i.e. when current is flowing. A sharp pointed cathode inside a spherical anode will have a radially symmetric charge density. (1/r^2). A plate cathode and a plate anode will have a fairly uniform charge distribution between them (but not spherical, obviously). You could certainly make a cylinder of charge that way. A fluorescent light is a good example. Similar things can be done inside resistive or semiconducting materials. If you put point contacts on opposite sides of a spherical resister the charge density wouldn’t be a sphere and it wouldn’t be uniform, but it would certainly have shape. You might be able to tailor some interesting charge density shape by that kind of approach.
The closest I can think of to a uniformly charged ball is a plasma ball. These are the charged particle equivalent of smoke rings. The flow is toroidal, and the charge density isn’t uniform, but these can come close to being spherical. These occur naturally but they are created in the lab mostly for injecting plasma into fusion reactors. See Marshall injector or theta-pinch.
One might try to plate a sequence of charged conducting shells and insulating shells on a spherical starter pellet. No idea about the practicality of doing so.
  • · Replies 19 ·
