How to determine a Limits of Integration of Wave Packet
Zaknife
Consider a force-free particle of mass m described, at an instant of time t = 0, by
the following wave packet:
<br /> \begin{array}{l}<br /> 0 \ \mathrm{for} \ |x| &gt; a + \epsilon \\<br /> A \ \mathrm{for} \ |x| ≤ a \\<br /> -\frac{A}{\epsilon} (x − a − \epsilon) \ \mathrm{for} \ a &lt; x ≤ a + \epsilon \\<br /> \frac{A}{\epsilon}(x + a + \epsilon) \ \mathrm{for} \ − a − \epsilon ≤ x &lt; a \\<br /> \end{array}<br />
where a, ε, and a normalization constant A are all positive numbers. Calculate mean
values and variances of the position and momentum operators x , x^{2} , \sigma_{x} \ and \ p_{x} .
<br /> 1=\int_{-\infty}^{\infty} |\psi(x,t)|^{2}<br />
I want to determine normalization constant A. I don't know what kind of integration limits i should use for the case:
A \ \mathrm{for} \ |x| ≤ a.
Do you have any ideas ? Thanks in advance !
You have a lot of intervals and need to use the fact that the integral will be a sum of integrals for each interval. So write all the integrals, compute them all the find A. Then compute all other items.
Ok , so far i have:
\int_{??}^{??} A^{2} dx (?) -\frac{A^{2}}{\epsilon^{2}}\int_{a}^{a+\epsilon} (x-a-\epsilon)^{2} dx +\frac{A^{2}}{\epsilon^{2}}\int_{-a-\epsilon}^{a} (x+a+\epsilon)^{2} dx =1. My question is what are the integration limits for the first integral ?
Where did you pick the first one from ? Is there an interval where the wavefunction is 1 ?
So, should i include first integral ? That was my problem/question ?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
