How to determine change in area of matrices tranformations.
The discussion focuses on determining the change in area of a square under various matrix transformations. The original square has vertices at (0,0), (0,1), (1,1), and (1,0), with an area of 1. Participants suggest using the vector cross product to find the area of the resulting parallelogram after transformation, as it directly relates to area calculations. There is a mention of using trigonometry, but the cross product is recommended for simplicity. Understanding how to apply these concepts is crucial for determining the change in area effectively.
Cacophony
Determine what the tranformation does to the square with vertices (0,0), (0,1), (1,1) and (1,0). Draw the image of the square under these tranformations. Then find the change in area of the square under these transformations.
a)
[1 1]
[1 2]
b)
[0 -1]
[2 -1]
c)
[4 1/4]
[3 1/3]
2. Homework Equations [/b]
I've plotted out all of the matrices on a graph but i don't understand how to find the change in area. How do I find the change in area?
The vertices (0,0), (0,1), (1,1) and (1,0) make a square of area 1. If you plotted the image they map to you should get some kind of parallelogram in each case. You can use trig to find its area, but it's probably easiest if you know how the vector cross product is related to area.
Still not really getting it. I have been out of school for a while so I need a refresher on how to use trigonometry to find the change in area. What does change in area even mean in this case?
You don't have to use trig if it's not fresh in you mind. Look at the vector cross product first. The cross product of two vectors is related to the area of the parallelogram that they span. Look it up.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
