How to distribute square roots without making common mistakes?
  • Topic:
  • Thread starter Cuberoot1
    Roots Square
Cuberoot1
I'm homeschooled, but it's gotten to the point that my Mom doesn't know how to do what she's teaching me anymore. So now I'm teaching myself with just a textbook and no one to explain it to me. I'm stuck on an issue probably simple, but I still need help. I believe I messed up on the last lines.
Please explain in detail.
#1
(sqrt7+4)(sqrt7-1) = (sqrt7+4)sqrt7-(sqrt7+4)1 = (sqrt7sqrt7+4sqrt7)-(1sqrt7+4•1) = 7+4sqrt7-sqrt7+4 = ?11+3sqrt7?
#2
(Sqrt2x+3)(sqrt2x-3) = (sqrt2x+3)sqrt2x-(sqrt2x+3)3 = (sqrt2xsqrt2x+3sqrt2x)-(3sqrt2x+3•3) = 2x+3sqrt2x-3sqrt2x+9 = ?2x+9?
I can't figure out what to add, and what to subtract on the last part.
#1
$$(\sqrt7+4)(\sqrt7-1) = (\sqrt7+4)\sqrt7-(\sqrt7+4)1 = (\sqrt7\sqrt7+4\sqrt7)-(1\sqrt7+4•1) = 7+4\sqrt7-\sqrt7+4 = ?11+3\sqrt7?$$
You're fine up until you distribute the final bracket. You have +4 and you need -4 (the minus sign means change the sign of every term in the bracket)
#2
$$(\sqrt{2x}+3)(\sqrt{2x}-3) = (\sqrt{2x}+3)\sqrt{2x}-(\sqrt{2x}+3)3 = (\sqrt{2x}\sqrt{2x}+3\sqrt{2x})-(3\sqrt{2x}+3•3) = 2x+3\sqrt{2x}-3\sqrt{2x}+9 = ?2x+9?$$
Are you familiar with the difference of two squares?
[math](a+b)(a-b) = a^2-b^2[/math]
Could you explain why I change all + to - ?
I understand the rest. Thanks.
Hi Cuberoot,
This is a common mistake that people make or overlook when quickly doing problems. Remember that $-(a+b)=-a-b$. You have to distribute the negative to both terms inside the parentheses. Maybe it helps to think of it like this instead. $-(a+b)=-1(a+b)$?
In your problem your second step is correct, but you need to fix this part...
$$(\sqrt7\sqrt7+4\sqrt7){\color{red}-(1\sqrt7+4\cdot1)}$$? How should the part in red but simplified?
