How to divide numbers that has decimal results mentally
  • Context: High School
  • Thread starter Thread starter Ese
    Numbers
The discussion revolves around techniques for mentally dividing numbers that yield decimal results. Participants share various methods, insights, and tricks related to mental calculations, particularly focusing on fractions and their decimal representations.
  • One participant suggests visualizing numbers and using a mental "shelf" for temporary storage while calculating.
  • Another participant emphasizes the importance of memorizing common fractions and their decimal equivalents to improve mental calculation speed.
  • Some techniques involve separating numerators into thousands, hundreds, tens, and ones for easier division.
  • A participant describes patterns in decimal representations, such as repeating cycles for certain fractions (e.g., .777... = 7/9) and the relationship between terminating decimals and their denominators (e.g., .125 = 1/8).
  • There are methods for calculating percentages mentally by breaking them down into simpler components (e.g., calculating 80% instead of 20% off).
  • One participant notes that fractions involving odd primes greater than 5 can be challenging for mental calculations due to longer repeating cycles.
  • Another participant describes a method for finding decimal equivalents of fractions involving powers of 2, illustrating the process with examples.
Participants generally agree on the usefulness of various techniques for mental division, but there is no consensus on a single best method, as different individuals may prefer different approaches.
Some techniques depend on prior knowledge of fractions and their decimal forms, which may not be universally known. Additionally, the effectiveness of these methods may vary based on individual familiarity with numbers and mental calculation strategies.
Individuals interested in improving their mental math skills, particularly in the context of dividing numbers and working with fractions and percentages.
Ese
Like what the title says, How can I do it?
For example,
1/3 = 0.333
43/3 = 14.3333
I've seen people do it mentally and I find it very astonishing. I want to learn how.
Mathematics news on Phys.org
I am sure different people do it differently..here are various techniques I use
First of all, you need to have good imagination and visualize your numbers up in mid "air" inside your head. You may need to have at least one "shelf" for temporary storage as you calculate the next number to add to the previous result.
You need to factorize (separate) your numerator into thousands, hundreds, tens, ones...AND keep a running sum of the divisions of the thousands, hundreds, tens, ones...
It helps to know a few fractions in advance...back in high school, during shop, we learned to use the caliper and the teacher made us memorize the typical fractions 1/2, 1/4, 1/8, 1/16, 1/32, 1/64, 1/128 and the corresponding multiples between 0 and 1 inch...since then, I became pretty good at impressing people when coming up with results with 3 or 4 decimal place accuracy.
Another thing is to be good with percentages...even if you can't get 3 decimal place accuracy, 1 or 2 will do just fine.
For sales with 20% off, you need to skip calculating the discount and THEN subtract that from the price...instead, take 100-20=80 and go straight and multiply the price times 80...again, separate the hundreds, from the tens, and one...multiply each times 80% (0.8) and then add them all back up.
Or, if the percent is not a nice multiple of 10%, but instead it is something line 35%...you need to separate this one too...100-35= 65% = 60% + 5% ...take the 60% of the price, plus 5% of the price ...this is often easier than trying to calculate 65% of the price in one shot.
Hope this helps.
there are certain tricks:
a repeating 1-digit cycle is that digit over 9:
.7777777... = 7/9
a repeating 2-digit cycle is those 2 digits over 99:
.16161616... = 16/99
if the "top" you get is divisible by 3 or 9, you can "simplifiy":
.48484848... = 48/99 = 16/33
decimals that terminate, have powers of 2 and 5 in the denominator:
.125 = 1/8
.04 = 1/25
fractions involving 6ths (when reduced) will have one "funny digit" and then repeat:
.166666... = 1/6
.833333... = 5/6
this is because 1/6 = (1/2)(1/3), the "odd digit in the pattern" comes from the 1/2 part, the repeating comes from the 1/3 part, or you could think of it as:
1/6 = 1/10 + (1/10)(2/3) = 3/30 + 2/30 = 5/30
there is a similar pattern with 12ths, "two funny digits" and then a repeat:
.41666666... = 5/12
fractions involving odd primes > 5 are things most people can't do in their head very fast, because the cycles of repetition can be very long. for 9/17, i have to use a calculator.
fractions involving only powers of 2 can be found this way:
1/4 = (1/2)(1/2). suppose we know 1/2 = .5
to find 1/2 of .5, we "multiply by 5, and move right one decimal place".
5x5 = 25, so we get .25
so to find 3/8, let's say, we know that 3/4 = .75, we "multiply by 5"
(75 x 5 = 350 + 25 = 375), and move over 1 decimal place, to get .375, done.
the reason this works is because 1/2 = (1/10)(5), and multiplying by 1/10 just "shifts the decimal point".
Thanks for the tips, I'm going to review these replies and help improve myself.
If you have anything else to add please do so. :D
you can see the pattern if you play with the numbers many times..
