How to explain TE20 mode in a rectangular waveguide from reflection
This discussion focuses on the explanation of the TE20 mode in rectangular waveguides, referencing Feynman's lectures on the TE10 mode. It establishes that the TE20 mode cannot be generated by placing a line source at the midpoint of the waveguide due to the zero electric field distribution at that point. Instead, positioning the line source at a/4 is necessary for generating the TE20 mode. Additionally, the conversation touches on the challenges of explaining TM modes in parallel plate waveguides, emphasizing the role of incident and reflected waves at the PEC boundaries.
  • Understanding of waveguide modes, specifically TE and TM modes.
  • Familiarity with Feynman's lectures on electromagnetic theory.
  • Knowledge of wave propagation principles in rectangular waveguides.
  • Basic concepts of standing waves and boundary conditions in waveguides.
  • Study the derivation of TE and TM modes in rectangular waveguides.
  • Learn about the mathematical representation of standing waves in waveguides.
  • Explore the implications of boundary conditions on wave propagation in waveguides.
  • Investigate the differences between TE and TM modes in parallel plate waveguides.
Electromagnetic theory students, waveguide engineers, and researchers in photonics and microwave engineering will benefit from this discussion.
Dale12
In Feynman's lectures, he explained the ##TE_{10}## mode of waveguide by considering a line source in the middle of waveguide as below:
since the adjacent sources are all out-of-phase, which means to have interference, the adjacent optical path would be about half of wavelength as below:
where
$$\sin\theta = \frac{\lambda_0}{2a}$$ (24.33)
and the relationship between wavelength in waveguide and free-space is show in this picture:
and we have:
$$\cos\theta = \frac{\lambda_0}{\lambda_g}$$,
combing with ##\sin\theta = \frac{\lambda_0}{2a}##, we have:
$$\lambda_g = \frac{\lambda_0}{\cos\theta} = \frac{\lambda_0}{\sqrt{1-(\lambda_0/2a)^2}}$$
Feynman then summarized with:
“ If the frequency is high enough, there can be two or more possible directions in which the waves will appear. For our case, this will happen if ##\lambda_0<\frac{2}{3}a##. In general, however, it could also happen when ##\lambda+0<a##. These additional waves correspond to the higher guide modes we have mentioned. ”
However, ##\lambda_0<\frac{2}{3}a## is corresponding to ##TE_{30}## modes and the differential phase between adjacent source is about 3/2 wavelength, but how to explain ##\lambda+0<a## which corresponding to one wavelength or ##TE_{20}## mode?
Thanks!
Science news on Phys.org
And also it seems work for TE modes of parallel plate waveguide, but it seems hard to explain TM modes of parallel plate waveguide.
I think I have make it clear now.
Q1: I think ##TE_{20}## mode can't be generated by putting a line source in the middle of wavguide, because the distribution of electric field for the ##TE_{20}## mode at a/2 is zero, in order to generate ##TE_{20}## mode, we can put the line source in the place of a/4, and mirror the source in the same way as Feynman does.
Q2: I think the line source can't generate the TM mode for the parallel plate waveguide, however, we can explain TE and TM both in view of incident and reflection from the PEC border of waveguide, and then for E components parallel to PEC, the reflection should have an -1, so that it has a form of sin function to be standing wave, and it's similar for H components perpendicular to PEC. for E components perpendicular and H components parallel to PEC, we have the same phase of reflection and then a standing wave of form cos function.
  • · Replies 20 ·
  • · Replies 33 ·
