How do you determine if a number is rational or irrational?
  • Thread starter Thread starter temaire
To determine if a number is rational or irrational, one must understand that rational numbers can be expressed as a ratio of two integers, while irrational numbers cannot. The discussion centers around the cubic equation x^3 - 4x + 4 = 0, where attempts to find rational roots reveal that none exist. The only real root identified is approximately -2.38, which is classified as irrational due to its non-repeating, non-terminating decimal nature. The rational roots theorem indicates that potential rational roots like ±1, ±2, and ±4 do not satisfy the equation. Thus, the conclusion is that the cubic equation has one irrational root and two complex roots.
temaire
x^3-4x+4
None
I tried using the quadratic formula but it doesn't work. I started with this, but I don't know what to do now.x^{3}+0x^2-4x+4
What exactly are you trying to do?!
x^3-4x+4 is an expression, not a problem statement! Do you mean that you are trying to find the roots of the equation x^3-4x+4=0?
yes I am trying to find the roots of the equation
Well, there are no simple solutions to this cubic equation. You can try using the cubic formula found here.
Is this the entire question, or is this part of a larger problem? Are you sure you have have written the equation correctly?
This is the correct equation, and it is the entire question.
Are you asked to use any specific method? (such as approximating the real root using Newton's method)
Are you allowed to use a calculator/computer?
No specific method is being asked but you can use a simple scientific calculator.
What methods have you been taught in whichever course this is for? Use one of those.
Edit~
TayTayDatDude said:
Try (x^3+0x^2-4x+4) = 0 (Just noticed you have)
After that, try "hunting" to find which number works. After you have found a number, use synthetic division.
There are no rational roots to this equation, so that method won't work.
Find the roots using Cardano's method.
D=(\frac{4}{2})^2 + (\frac{-4}{3})^3=4 - \frac{64}{27}=\frac{108-64}{27}=\frac{44}{27} > 0, so it got one rational and two complex roots.
The rational one is ~(-2.38)
The root (-2.38) is real not rational. The rational roots theorem tells you that the only possible candidates for rational roots of this equation are \pm 1, \pm 2, and \pm 4...and since none of these are roots; there are no rational roots.
Rational numbers are also real numbers. So I suppose -2.38...(infinite number of decimals) is irrational number (also real number).
A rational number is a real number that can be expressed as a ratio of two integers...for example, 1/3, 0.25, and 3658793659/548709568017097 are rational numbers.
However, things like \pi, \sqrt{2} and any non-repeating non-terminating decimal are irrational numbers.
