How to find cord tension and hinge force?
To find the cord tension and hinge force for a 5 kg beam hanging at a 30-degree angle with a 10 kg mass, start by drawing a free body diagram. Apply the principle of static equilibrium, where the clockwise torque equals the counterclockwise torque. The calculated values for tension and hinge force are 69N and 130N, respectively. Ensure to account for all forces acting on the beam, including the weight of the beam and the attached mass. This method will yield the required forces accurately.
matahari
A 5 kg 10 m beam is hanging from a wall. The angle between the cord and the wall is 30 degrees, and a 10kg mass is situated one meter away from the wall. How do I solve for cord tension and hinge force?
Torque_cw=Torque_ccw?
it says the answers are 69N and 130N for tension and force respectively.
Draw a free body diagram of the beam and the cord, with the weight attached to the beam.
Write equations of static equilibrium for the free body so that you can determine the unknown tension and the hinge force.
