How to find eigenvectors of a 3 by 3 matrix
To find the eigenvectors of the matrix {{2,-1,-1},{-1,2,-1},{-1,-1,2}}, the characteristic equation x^3 - 6x^2 + 9 yields eigenvalues 0, 3, and 3. For the eigenvalue x=0, three equations arise from the matrix multiplication, which can be solved using methods like substitution or Gaussian elimination. For the repeated eigenvalue x=3, two linearly independent eigenvectors are needed; any vector can be chosen to start, and then another can be derived from it. The discussion highlights confusion around solving for eigenvectors and emphasizes the importance of understanding the relationship between eigenvalues and their corresponding eigenvectors. Ultimately, the user resolved their questions with assistance.
gboff21
Question: find the eigenvectors of {{2,-1,-1},{-1,2,-1},{-1,-1,2}}.
Equations: none
Attempted answer:
I have the characteristic equation as x^3-6x^2+9 which gives eigenvalues as 0 3 and 3. This is correct says wolfram alpha
for x=0 {{2,-1,-1},{-1,2,-1},{-1,-1,2}}•{x,y,z}=0
I get 3 different equations! How does this give an answer?
For x=3 I get -{{1,1,1},{1,1,1},{1,1,1}•{x,y,z}=0
which gives v=anything
So what the hell??
Please help!
For x=0 you get three equations for three unknowns. That's exactly what you need. Use whatever method you prefer to solve (substitute, gaussian elimination, etc.) for x,y, and z.
For x=3 you have repeated roots. Since this multiplicity is two, all you need to do is find two eigenvectors that work that are linearly independent. As you demonstrated, anything works, so just pick something simple for the first and then use that one to determine a second.
For x=0. How do you get the right answer cos I constantly get {3,1,1} which is wrong.
And for x=3 how do you do do it. I don't understand how you use one randomly picked one, say {1,1,1} (which is one of the answers), to work out another!
Never mind I've done it. Thanks
