How to find spring constant & damping coef of speaker flexure
To determine the spring constant and damping coefficient of a speaker flexure, a small force-measuring device can be used to measure displacement across various forces, which will provide the spring constant (k). An alternative method involves placing weights on the speaker while measuring displacement with calipers. For the damping coefficient, tapping the center of the speaker cone and using an oscilloscope to capture the damped sinusoid output can yield the necessary data. The waveform from this output can then be analyzed to calculate the damping coefficient. These methods offer practical approaches for obtaining the required parameters for the transfer function in audio speaker applications.
ivan6496
Hi anyone,
I'm doing my final year project requires to use audio speaker. I need to know the two parameters for my transfer function. They are spring constant and the damping coefficient of the speaker flexure. Can anyone give me some idea?
Best Regards,
Ivan
Just use a small force-measuring device to measure the displacement for a range of forces. That will give you the k value. You could even just turn the speaker vertical and set small weights on it and measure the displacement with calipers.
As for the damping coefficient, maybe you can tap it (the center of the cone) and measure the output from the speaker with an oscilloscope. Capture the damped sinusoid output (probably fairly small for light taps), and calculate the damping coefficient from that waveform.
Speaker K & b (thank you)
Hi Berkeman,
Thanks for the help. Appreciated.
Best Regards,
Ivan:smile:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
