How to find the final height of a moving object
  • Thread starter Thread starter lordloss
    Final Height
To find the final height of the armadillo, the initial speed is calculated as 3.54 m/s, and its speed at 0.523 m is 1.5 m/s. The challenge lies in determining how much higher it goes after reaching this height. The correct approach involves using the kinematic equations, specifically recognizing that the final velocity at maximum height is 0 m/s. The user is advised to correctly apply the kinematic equation by substituting the appropriate velocities to find the additional height.
lordloss
A startled armadillo leaps upward, rising 0.523 m in the first 0.206 s. (a) What is its initial speed as it leaves the ground? (b) What is its speed at the height of 0.523 m? (c) How much higher does it go?
The five Kinematic equations
I worked out A and B and got the following answers:
(a) 3.54 m/s
(b) 1.5 m/s
I just can't figure out the last part, C, on how to find how much higher the armadillo goes. Can anyone help me out with this?
I would use 2a(x-x_0)=v^2-v_0^2. Do you see how you can use this to solve (c)?
I'm using WileyPlus and its not taking any of the answers I have come up with.
I inserted all the variables into this modified equation to find the final x variable:
X=(V^2-V0^2+2aX0)/2a
Did I do the algebra wrong?
I keep getting 1.047m.
That's wrong, and it looks like you are plugging in the wrong velocities here.
For part (c), the armidillo's "initial" velocity is the 1.5 m/s it has at the 0.523 m height. It's "final" velocity is the velocity it has when it has reached it's maximum height (and that velocity is ____?)
