How to find the volume between y = 2√xz and y = 1?
  • Thread starter Eclair_de_XII
  • Tags
    Volume
In summary: From there the next step is to integrate the density of ##Y## over the appropriate bounds. You'll get a messy integral, but it's a standard problem. I don't think I'm hiding anything here, but I'm going to leave this as an exercise for you. I'd be happy to check your work if you get stuck, but this should be enough to get you started.
Eclair_de_XII
1,083
91
"Find ##P(Y^2>4xz)##, where ##(x,y,z)\in (0,1)^3##."
##P(Y^2>4xz)=P(Y>2\sqrt{xz})+P(Y<-2\sqrt{xz})=P(Y>2\sqrt{xz})=P(1>Y>2\sqrt{xz})##
Here, I set the boundaries for integration over this "wedge", for the lack of a better term.
##2\sqrt{xz}\leq y < 1##
##\frac{1}{4z}\leq x < ...##
I tried drawing a picture, but all I got from the information was that x could not be bounded by 0 or 1. The curve doesn't touch the any of the axes except at the origin.
well I don't think you stated that ##Y## is uniform taking values in 0,1 but I suspect that it is given that your post title asked for Volume...
Two other things:
1.) The issue in some sense is something seems missing. ##Y## is a random variable and so it presumably comes with a cdf and x, y are simply fixed values, apparently not random variables. There isn't any integration work to be done here if you already have the CDF. Just use the CDF of Y and then negate it and add one to get its complement. That being said, I have a hunch you want X and Z to be uniform random variables as well, though this is not stated anywhere
2.) In terms of pattern recognition this looks to be a touch different, but extremely close to this problem from October
https://www.physicsforums.com/threads/probability-theory-understanding-some-steps.957391/
Yes, they are all random variables distributed uniformly in the unit cube in ##\mathbb{R}##.
And yes, that problem is exactly the same, except that the problem I'm doing requires me to find the probability of finding two distinct real roots.
Notation matters: I cannot figure out if you mean
$$P(Y^2 > 4 X Z)\hspace{4ex}(1)$$
or
$$P(Y^2 > 4 x z)\hspace{4ex}(2)$$ exactly as written. In (1), ##X,Y,Z## are iid ##U(0,1)## random variables, while in (2) only ##Y## is random.
If you really did mean (1), it is important to remember the distinction between a random variable and a realization of that variable. Random variables are typically denoted by upper-case letters near the end of the alphabet, while realizations of those variables are typically (but, of course, not always) denoted by lower-case versions of the same letters.
If you meant (2) the problem is essentially trivial, with a one-line solution needing no fancy calculations.
Do you mean that the problem becomes a one-dimensional integration problem if I am not integrating with respect to the random variables ##X,Z##?
I'm not sure whether you finished your last exercise on right continuity of CDFs, but the thought that immediately comes to mind is a direct follow up to it.
conditioning on ## 4XZ = \alpha## for ##\alpha \in [0,1]##
what is ##P(Y^2>\alpha)## and what is ##P(Y^2\geq \alpha)##?
(hint: there are no jump discontinuities in the CDF for the random variable ##Y^2##).
The conclusion should be that the exercises are in fact probabilistically the same. I'd formalize this point via conditional expectations with two different indicator random variables, but the basic idea is zero probability of 'collisions' with continuous random variables.
They should be the same, right? No jump discontinuities mean ##P(Y^2=\alpha)=0## and ##P(Y^2>\alpha)=P(Y^2\geq \alpha)##.
Anyway, are you asking me to find: ##P(Y^2\geq a|\alpha = a)##? I kind of already went ahead and did part of the method described by the person whose topic you linked me to.
##P(X\geq \frac{y^2}{4Z}|Y=y)=\int_{\frac{1}{4}y^2}^1 \int_{\frac{y^2}{4z}}^1 dx dz =\int_{\frac{1}{4}y^2}^1 (1-\frac{y^2}{4z})dz=(z-\frac{y^2}{4}ln(z))|_{\frac{1}{4}y^2}^1=
[1]-[\frac{1}{4}y^2-\frac{1}{4}y^2ln[(\frac{1}{2}y)^2]]=\\1-[\frac{1}{4}y^2-\frac{1}{2}y^2ln(\frac{1}{2}y)]##.
And so...
##P(X\leq \frac{y^2}{4Z}|Y=y)=1-P(X\geq \frac{y^2}{4Z}|Y=y)=1-(1-[\frac{1}{4}y^2-\frac{1}{2}y^2ln(\frac{1}{2}y)])=\frac{1}{4}y^2-\frac{1}{2}y^2ln(\frac{1}{2}y)##
basically, yes. ##P(Y^2\geq \alpha\big)## is merely the complementary CDF of a random variable ##Y^2## (supposing we ignore zero probability events underlying the equality case)
from here you just need the density associated with the random variable ##\big(4XZ\big)## and then to integrate over this density. It's a bit ugly as is common for finding distributions for products of random variables.
I haven't learned how to find the density of the product of two independent r.v.'s, but I did attempt to get a distribution function..
##P(4XZ<\alpha)=\int P(4XZ<\alpha|X=x)P(X=x)dx=\int P(Z<\frac{\alpha}{4x})P(X=x)dx\\
=\int \int_0^{{\alpha}{4x}}dzP(X=x)dx=\int {\frac{\alpha}{4x}}dx=\frac{\alpha}{4}ln(x)##
Even if this were right, I'd still have to determine the bounds of integration w.r.t. ##x##.
on the computational side, this *is* in some sense, the exercise. Alternative approaches would be to take advantage of positivity and do a log transform of the random variables, sum (i.e. convolve) them, then exponentiate back, or if you want to focus on, in effect, getting the CDF, then what you've done below should ultimately get you there.
High level this seems like an ok idea. Some cleaup of course is needed e.g. as stated before ##P(X=x) =0##-- what you actually want is a density there.
edit:
this may be overkill, but really to get the above, I'd setup an event ##B## that is ##4XYZ \lt \alpha## (note you should be able to confirm that this has the same probability as ##4XYZ \leq \alpha## which is in fact preferable since this is how CDFs are written)
for some arbitrarily chosen ##\alpha \in (0,1)##. So what you have is
##P(B) = E\Big[\mathbb I_B \Big] = E\Big[E\big[\mathbb I_B \big \vert X\big]\Big]##
In some sense this is close to what you've done above, but the chaining on of ##P(X=x)## did not quite sit well with me. This approach should make it clear that
##E\big[\mathbb I_B \big \vert X\big]## is a random variable that takes on values
##P(Z<\frac{\alpha}{4X})##
or if you prefer, for each ##X(\omega) = x## it takes on values
##P(Z<\frac{\alpha}{4x})##
and it should be clear that when you take expectations of this random variable
##E\big[\mathbb I_B \big \vert X\big]## you are using the density of ##X## -- this is part of a general approach to conditional expectations.
If you want to focus on ##P(4XZ<\alpha)##: you could then set this up to have an event ##A## where ##4XZ\lt \alpha## and ##\alpha := Y^2(\omega)##
giving you
##P(A) = E\Big[\mathbb I_A \Big] = E\Big[E\big[\mathbb I_A \big \vert Y^2\big]\Big]##
in which case you can get by with the CDF for ##(4XZ)## and then merely integrate over the density of ##(Y^2)##
I haven't been taught how to do any of that...
##E[E[\mathbb{I}_B∣X]]##
I'm very confused by this notation every time I see it and have no idea what it is supposed to mean.
You make the job not at all easy for us -- when you leave "relevant equations" blank, we are stuck guessing at what you know and don't. It is the most important part of the template. If you want a belt and suspenders approach, stating books you're using / have used may also help bridge gaps -- this may be overkill, but that's why they call it belt and suspenders.
Since you're in an "advanced probability" course, I simply refuse to believe you've never seen conditional expectations before or that you can't map the notation I gave for the tower property of (iterated) expectations to what you've seen before. There's only a small handful of common notations for this -- I gave one of them. The same for indicator random variables.
edit:
For a reference that uses almost identical notation, consider:
http://www.randomservices.org/random/expect/Conditional.html
in particular (3) and the section called "conditional probability" about a fifth of the way down, though they use ##1_A## for an indicator instead of ##\mathbb I_A## -- it is a very minor difference.
I'm sorry for all the trouble... I am using Grimmett's Probability: An Introduction, and I'm on chapter six with joint and multivariable distributions, I think it was called. I couldn't think of any relevant equations applicable to the problem. I'm on the section right before the conditional probability.
so it sounds like you will get to conditional probability very soon, and then I can breathe a little easier. The index suggests that conditional expectations come up on page 33 (past) and page 99 (upcoming).
It sounds like they don't emphasize conditional expectations in this text, which is a pity since they are one of the gems of probability theory... (Blitzsteins book does a good job on this and even has a more general variant of your problem, but you don't have control over the book I'd wager.)
As for this problem, I'd suggest returning to
Eclair_de_XII said:
##P(4XZ<\alpha)=\int P(4XZ<\alpha|X=x)P(X=x)dx=\int P(Z<\frac{\alpha}{4x})P(X=x)dx ##
I think this is close... one issue is again use density for ##f_X(x)## and the other is you want to, very carefully, convert
##P(Z<\frac{\alpha}{4x})## into the cdf for Z.
so what you have is
##P(4XZ<\alpha)= P(4XZ\leq \alpha)= \int P(Z\leq \frac{\alpha}{4x})f_X(x)dx ##
you want to integrate over X. it is non-negative so you can formally do this over ##(0, \infty)## but you should recognize that ##f_X(x)=0## for ## x \gt 1## which should simplify the calculations. You know the CDF for ##Z## so you should be able to get the desired result fairly easily I think.
##P(Z<\frac{α}{4x})## into the cdf for Z.
Okay, so first thing: the marginal density function ##f_X(x)## isn't one? Second thing, this was the closest I could come to a coherent answer: ##P(Z>\frac{\alpha}{4x})=\int_{\frac{\alpha}{4x}}^1dz## and ##P(4XZ>\alpha)=\int_{\frac{\alpha}{4}}^1 \int_{\frac{\alpha}{4x}}^1 f_X(x)dzdx##. It's basically the same as before, and I'm afraid I'm not really understanding this problem all that much.
for ##x \in (0,1)## it is 1 -- since X is uniform in (0,1). Definitely.
one nit: do you want ##P(Z>\frac{\alpha}{4x})## or ##P(Z<\frac{\alpha}{4x})##? setting aside zero probability events they are complementary of course.
Honestly I think you're close. My general view is don't start from scratch. ##Z## is a uniform random variable (in fact all 3 random variables are iid uniforms right?). Can't you just use the CDF for ##Z## here? I'd probably split it the integral into case where ##\frac{\alpha}{4x} \geq 1## (because your CDF always evaluates to one in that case, right?) and otherwise. But I happen to really like CDFs.
The issue is that this problem has some careful reasoning required with events, and is computationally a little bit nasty, though I kind of like the way you've proposed to solve it.
Okay, so:
##P(4XZ>y^2)=\int_{\frac{y^2}{4}}^1 \int_{\frac{y^2}{4x}}^1 f_X(x)dzdx=\int_{\frac{y^2}{4}}^1 (1-{\frac{y^2}{4x}})dx\\
=[x-\frac{y^2}{4}ln(x)]|_{\frac{y^2}{4}}^1=1-[\frac{y^2}{4}-\frac{y^2}{2}ln(\frac{y}{2})]## and ##P(4XZ<y^2)=\frac{y^2}{4}-\frac{y^2}{2}ln(\frac{y}{2})##.
So:
##P(4XZ<Y^2)=\int_0^1P(4XZ<y^2)P(Y=y)dy=\int_0^1 [\frac{y^2}{4}-\frac{y^2}{2}ln(\frac{y}{2})]dy\\
=\frac{1}{4}\int_0^1 y^2(1-2ln(\frac{y}{2}))dy\\
=\frac{1}{4}[\frac{1}{3}y^3(1-2ln(\frac{y}{2}))+\frac{2}{3}\int y^2 dy=[\frac{1}{4}[\frac{1}{3}y^3(1-2ln(\frac{y}{2}))+\frac{2}{9}y^3]_0^1\\
=\frac{1}{4}[\frac{1}{3}(1+2ln(2))+\frac{2}{9}]-\frac{1}{4}(-\frac{2}{3}\lim_{y\rightarrow 0}\frac{ln(y)}{y^{-3}})\\
=\frac{1}{4}[\frac{5}{9}+\frac{2}{3}ln(2)]=\frac{5}{36}+\frac{1}{6}ln(2)##
My notation might be a bit off, but it's mostly because I am not used to working with conditional continuous distributions...
Eclair_de_XII said:
##P(4XZ<Y^2)=\int_0^1P(4XZ<y^2)P(Y=y)dy=\int_0^1 [\frac{y^2}{4}-\frac{y^2}{2}ln(\frac{y}{2})]dy\\##
two red flags that jump off the page:
i.) ##P(Y=y) =0 ## because ##Y## (and ##Y^2## for that matter) is a continuous random variable. Again you need a density here.
ii.) you cannot integrate directly over the density of ##Y##. You need to either follow change of variables formulas or compute the density of ##Y^2## and use that. It's very easy to mess this up -- and this is part of the reason why I fall back on the conditional expectations formalism -- it helps me avoid this pitfall.
Eclair_de_XII said:
My notation might be a bit off, but it's mostly because I am not used to conditional continuous distributions...
Honestly this is a pretty brutal problem to insert *before* the conditional probabilities section.
So I'm going to have to compute: ##P(4XZ<Y^2)=\int_0^1 P(4XZ<y^2)f_{Y^2}(y^2)dy##?
right...
You should be able skip some unpleasantness with change of variables such that
##S := Y^2##
for ##s \in (0,1)## or for ##y \in(0,1)## for that matter
##f_S(s) = f_Y(y) \frac{dy}{ds} = f_Y(s^\frac{1}{2}) \frac{1}{2 \sqrt{s}} = \frac{1}{2 \sqrt{s}}##
Do I do any change of variables with the ##P(4XZ<y^2)## term?
I like to hide the transformations, so just write it as
##P(4XZ<s)##
or better
##P(4XZ\leq s)##
where of course ##\alpha := s## as before
When I think about it, this is a double layered conditional probability problem -- pretty terrible to assign it before the section on conditional probabilities.
Okay...
##P(4XZ<S)=\int_0^1 P(4XZ<s)f_S(s)ds=\int_0^1P(4XZ<s)f_Y(\sqrt{s})\frac{1}{2\sqrt{s}}ds\\
=\int_0^1 [\frac{s}{4}-\frac{s}{2}ln(\frac{\sqrt{s}}{2})]\frac{ds}{2 \sqrt{s}}=\frac{1}{8}\int_0^1\sqrt{s}(1-2ln(\frac{\sqrt{s}}{2}))ds\\
=\frac{1}{8}[\frac{2}{3}(1-ln(s)+2ln(2))+\frac{2}{3}\int s^{\frac{1}{2}}=\frac{1}{8}[\frac{2}{3}s^{\frac{3}{2}}(1-ln(s)+2ln(2))+\frac{4}{9}s^{\frac{3}{2}}]|_0^1\\
=\frac{1}{8}[\frac{2}{3}+\frac{4}{3}ln(2)+\frac{4}{9}]=\frac{5}{36}+\frac{1}{6}ln(2)##
On a side-note, I really must learn how to practice transforming r.v.'s more. Even though the professor hjasn't taught me conditional continuous probabiltiies, he has gone over transformations of r.v.'s many many times, and I can only chide myself for not bothering to apply what he's taught me. It really makes me think I'm not cut out for probability work if I'm this lazy and unmotivated. Not to mention really tired of school...
Eclair_de_XII said:
On a side-note, I really must learn how to practice transforming r.v.'s more. Even though the professor hjasn't taught me conditional continuous probabiltiies, he has gone over transformations of r.v.'s many many times, and I can only chide myself for not bothering to apply what he's taught me. It really makes me think I'm not cut out for probability work...
can I suggest you take a look at some of the exercises in Blitzstein? You don't necessarily even need to buy the book-- there's selected problems with solutions available at
http://projects.iq.harvard.edu/file..._solutions_blitzstein_hwang_probability_2.pdf
sometimes the things in there are a little too cute, but your problem reminds me of number 24 on page 74 of 112 of the pdf (the actual printed page number is 72) -- this is one of many problems in the Transformations chapter. It is about the product of positive random variables and has this character Jacobno who refuses to use Jacobians...
Maybe doing some of the exercises in that chapter without peeking at the solutions until say 15 minutes of struggle would be helpful? (I don't think your book has solutions which can frustrate deliberate practice attempts when going through problems you're shaky on...)
I suppose it's worth looking at. But I have to focus on my other school assignments that are worth credit towards my grade. It's been like this for the whole semester. Lately, I haven't had the free time to do practice problems at my leisure despite having only three math classes. Thanks for your help besides. You have been a great help in the past three days I spent struggling and stressing over this problem...
Hang in there. 3 math classes can be a lot, depending on how much it's stretching your mind. These are some of the more interesting probability problems on the site, though I think this particular problem gets mired in computational details. The real interesting stuff in your book seems to be in chapters 9+...
Eclair_de_XII said:
Okay...
I should flag that I think, again, procedurally, you are close, but I grew suspicious of your final answer since it matched post 18 (but that did not account for change of variables/ density) which said
edit:
I wrote a whole bunch of other things but belatedly realized you had in fact addressed them. Apologies.
There's a lot of mechanical things to run down though I can't quite tie out how post 18 and this most recent solution agree.
This was actually the answer given in the back of the book.
What is the equation for finding the volume between two curves?
The equation for finding the volume between two curves is ∫(upper curve - lower curve) dx or ∫(right curve - left curve) dy. This can also be written as ∫(f(x) - g(x)) dx or ∫(f(y) - g(y)) dy, depending on the orientation of the curves.
How do I determine the limits of integration for finding the volume between two curves?
The limits of integration can be found by identifying the points where the two curves intersect. These points will serve as the upper and lower limits for the integral. If the curves do not intersect, then the limits can be determined by finding the points where the curves are closest to each other.
Can I use the disk or washer method to find the volume between two curves?
Yes, the disk or washer method can be used to find the volume between two curves as long as the curves are revolved around the same axis. The formula for using these methods is V = π∫(upper curve)^2 - (lower curve)^2 dx or V = π∫(right curve)^2 - (left curve)^2 dy.
What is the difference between the volume between two curves and the area between two curves?
The volume between two curves refers to the 3-dimensional space enclosed by the two curves. On the other hand, the area between two curves refers to the 2-dimensional space between the two curves on a plane.
Can I use a calculator to find the volume between two curves?
Yes, you can use a graphing calculator or any other tool that can perform numerical integration to find the volume between two curves. Simply input the equations for the two curves and use the appropriate limits of integration to find the volume.
