How to find velocity from an acceleration versus time graph?
To find velocity from an acceleration versus time graph, one must understand the relationship between acceleration and velocity. The equation a = dV/dt indicates that acceleration is the rate of change of velocity over time. By rearranging this, dV = a*dt, it becomes clear that velocity can be determined by integrating acceleration over time. Thus, V = ∫a dt provides the method to calculate velocity at a specific time, such as t=5.0. This approach effectively translates the area under the acceleration curve into velocity values.
jmanz
How to find velocity from an acceleration versus time graph??
I have an... a vs t graph, how do i find the velocity at a given time ex: t=5.0
Ask yourself, what is the definition of acceleration.
Does a = dV/dt help??
It helps a bit if you rearrange things.
a = dV/dt
dV = a*dt
V = ∫a dt
