How to get zero electric field inside spherical shell without using Gauss law
In summary, the conversation is discussing the proof of the electric field inside a spherical shell with zero constant surface charge density. The usual proof involves using Gauss's law, but the person is trying to solve a problem using spherical coordinates and Coulomb's law. They run into difficulties with their steps and realize that they have not included the vector nature of the electric field. The correct starting equation is shown and it is explained that the integral is a volume integral. The conversation ends with the suggestion to try working through the problem on their own.
chemfirus
Now, i am trying to prove that electric field inside spherical shell whose constant surface charge density [tex]\rho[/tex] is zero. Usually, it is proved by using Gauss law (there is no charge enclosed inside gaussian surface so there is no electric field inside the sphere). But, whe i am trying to solve schaum electromagnetics problem (actually, it is not my homework and i don't have to do it) no. 2.53 i was asked to prove it. Because in the chapter is not explained gauss law yet, i try to prove it. Next is my step:
1) I would like to prove it in spherical coordinate. So, i need to use next equation:
d2 = R12 + R22 - 2*R1*R2[cos[tex]\theta[/tex]1*cos[tex]\theta[/tex]2 + sin[tex]\theta[/tex]1*sin[tex]\theta[/tex]2*(cos([tex]\phi[/tex]1-[tex]\phi[/tex]2))].....(1)
Equation (1) is used to find distance between two points (or vector), [tex]\vec{R1}[/tex] and [tex]\vec{R2}[/tex], in spherical coordinate. I would use it as R in coulomb's law.
2) The next step is to model the equation in coulomb's law:
([tex]\rho[/tex]/(4*[tex]\pi[/tex]*[tex]\epsilon[/tex]))*[tex]\oint[/tex](R12sin[tex]\theta[/tex]1/(R12 + R22 - 2*R1*R2*cos[tex]\theta1[/tex])) d[tex]\theta[/tex]1d[tex]\phi[/tex]1...(2)
In equation (2), i have made [tex]\theta[/tex]2 = 0 because i put the evaluated point at [tex]\theta[/tex] = 0 (or simply at z axis in cartesian coordinate). R1 is distance between dS and centre point, R2 is distance between evaluated points with centre points. So, distance between dS and evaluated point got by using equation (1).
I have tried to integrate the equation (2) and i can't prove that the result is zero. I got a natural logaritmic equation at first integral (integrate with d[tex]\theta[/tex]1). When i substitute upper and lower limit with [tex]\pi[/tex] and 0 i don't get zero result. I don't try the second integral because i am not sure i would get the result i want.
Suddenly, i aware that i don't use unit vector yet in equation (2). It makes the distance not become (R12 + R22 - 2*R1*R2*cos[tex]\theta1[/tex])(3/2) like equation we usually met. But, i don't know what is the vector in spherical coordinate. How to write it and how to evaluate it? I stop to use spherical coordinate and try to use cartesian coordinate. But, it is extremely difficult even only for evaluating dS . I get a form which i can't use my integral technique. I really...really stuck now. You need to know that two equations above is equations i derive alone. So, ther is possibility to be wrong.
Which is wrong from my steps? Is the equation? Or model? Could you help me?
Likes azizlwl
Your equation doesn't even give 0 for [tex]R_2 = 0[/tex]. The reason is that you are only summing up the magnitude of the electric field at the point R_2, you are not including the vector nature of the electric field. The correct starting equation is
[tex]
E(\vec{r}) = \frac{1}{4\pi \epsilon} \int \frac{\rho(\vec{r'}) (\vec{r} - \vec{r'})}{|\vec{r} - \vec{r'}|^3} d^3 r'
[/tex]
Note the extra factor of [tex]\vec{r} - \vec{r'}[/tex] has its magnitude canceled by the extra factor in the denominator so that only the direction of r-r' is kept.
It's a bit easier to calculate the potential and show that it is independent of R2 if R2 < R1.
[tex]
[/tex]
That's what i mean in last sentences. I don't include the vector in the equation. When iwant to use it, i don't understand how to. Is the magnitude of [tex]\vec{a}[/tex][tex]\theta[/tex] is [tex]\theta[/tex]1 and there is no magnitude in [tex]\vec{a}[/tex][tex]\phi[/tex]? In other words, the miss vector numerator in equation (2) above is
(R1 - R2)[tex]\vec{a}[/tex]r + ([tex]\theta[/tex]1 - 0)[tex]\vec{a}[/tex][tex]\theta[/tex] ?
I still confuse with the equation you wrote. Is it surface integral or volume integral? Whati is d3r' means? And, if you would, could you evaluate your integral and show me the prove. I need concrete solution. Anyway, thanks for helping me.
In spherical coordinates, [tex]\vec{r} = r \hat{r}[/tex]. You have to be careful when subtracting two vectors like that because they each have a different [tex]\hat{r}[/tex] direction. So you have to write it in cartesian coordinates. In that case, [tex]\vec{r} = r \sin \theta \cos\phi \, \hat{x} + r \sin\theta \sin\phi \, \hat{y} + r\cos\theta \, \hat{z}[/tex]. Then you do the subtraction, keeping in mind that [tex]\vec{r}[/tex] and [tex]\vec{r'}[/tex] each have their own [tex]\theta,\phi[/tex] components. In this case it will be simple, because you restrict [tex]\hat{r}[/tex] to the z axis, so when you integrate [tex]\phi[/tex] the x and y components will drop out.
Yes, it's a volume integral. If you have a thin shell of charge, then you define [tex]\rho(\vec{r}) = \sigma \delta(r - R)[/tex] where you use the Dirac delta function. If you are not familiar with the Dirac delta, then the result is that it reduces to:
[tex]
E(\vec{r}) = \frac{1}{4\pi\epsilon}\int \frac{\sigma (\vec{r} - R \hat{r'})}{|\vec{r} - \vec{r'}|^3} R^2 \sin \theta' \, d\theta' \, d\phi'
[/tex]
which is a surface integral. I'm not going to do the whole thing for you, since (a) it's a good practice problem for you to work through yourself, and (b) I don't feel like it.
(Btw, when you use tex on these forums, it's best to use it for the whole equation rather than just a few special symbols. It's a lot easier to read that way.)
[tex]
[/tex]
Thank you very much! I have just done it! Like your suggest, i use cartesian coordinate vector instead of spherical coordinate vector. This is the final equation i evaluate:
[tex]\frac{\rho}{4\pi\epsilon}[/tex][tex]\oint[/tex][tex]\frac{R_1^2\sin\theta_1}{R_1^2+R_2^2-2R_1R_2\cos\theta_1}[/tex][tex]\frac{(R_1\sin\theta_1\cos\phi_1)\widehat{a_x}+(R_1\sin\theta_1\sin\phi_1)\widehat{a_y}+(R_1\cos\theta_1-R_2)\widehat{a_z}}{\sqrt{R_1^2+R_2^2-2R_1R_2\cos\theta_1}}[/tex]d[tex]\theta_1[/tex]d[tex]\phi_1[/tex]
Its quite difficult for me to evaluate the integral. Because of symmetry reason i think components in [tex]\hat{a_x}[/tex] and [tex]\hat{a_y}[/tex] is zero when i evaluate it. So, i choose to pass it. I just evaluate the [tex]\hat{a_z}[/tex] component. But, it is still difficult for first time. Fortunately, thanks to god, i could do it and get zero result in the end. Many things i have got rom this question.
And, special thanks for Kanato for helping me...
Yeah, the x and y components vanish. Do the [tex]d\phi_1[/tex] integral first, you will see that gives zero.
There is a more 'arm waving' but valid method, I think.
Take any point inside the sphere and draw a chord through it. Take an elemental square 'pyramid' about the chord. The two ends of this bow-tie will meet the surface of the sphere and form identical shaped surfaces. The areas will be proportional to the square of the distances. The forces on a unit charge will be inversely proportional to the distance and proportional to the area intersected. And the two forces will be exactle opposite in direction, producing a resultant of zero. If you integrate over a whole sphere (around the point in question) you will get zero.
I suppose it would be better to use an elemental pyramid of d phi and d theta rather than dx and dy but the same argument would apply, I think.
Minimal Maths makes it easier for me!
Related to How to get zero electric field inside spherical shell without using Gauss law
1. How can a spherical shell have a zero electric field inside?
It is possible to have a zero electric field inside a spherical shell by ensuring that the net charge enclosed by the shell is zero. This can be achieved by placing equal and opposite charges on the inner and outer surfaces of the shell, cancelling out the electric field.
2. Can this be achieved without using Gauss law?
Yes, it is possible to get a zero electric field inside a spherical shell without using Gauss law. This can be done by considering the symmetry of the system and using the principle of superposition, where the electric field due to each individual charge is added together.
3. What is the role of symmetry in achieving a zero electric field inside a spherical shell?
Symmetry plays a crucial role in achieving a zero electric field inside a spherical shell. The spherical symmetry of the shell ensures that the electric field due to each individual charge is equal in magnitude and opposite in direction, resulting in a cancellation of the electric field inside the shell.
4. Can a zero electric field inside a spherical shell be achieved with any distribution of charges?
No, it is not possible to achieve a zero electric field inside a spherical shell with any distribution of charges. The distribution of charges must be symmetric, with equal and opposite charges on the inner and outer surfaces of the shell, in order to cancel out the electric field inside the shell.
5. Is the electric field inside a spherical shell always zero?
No, the electric field inside a spherical shell is only zero if the net charge enclosed by the shell is zero. If there is a non-zero net charge enclosed, then there will be an electric field inside the shell, following the inverse square law for electric fields.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
