How to measure electrical frequency?
To measure electrical frequency, an electronic frequency is required, which involves converting input frequencies to voltage. Various transducers can convert mechanical frequencies to electronic frequencies, with the LM2917 chip from National Semiconductor being specifically designed for this purpose. A common setup includes a generator, transformer, Schmitt trigger, LM2917, and a PLC for monitoring. There is some debate about the effectiveness of Schmitt triggers in sensing frequency without a magnetic pickup. The LM2917 primarily detects the positive peaks of sinusoidal waves, which is crucial for accurate frequency measurement.
killjoy_scofiel
in f to V converter, input is frequencies . Is that electrical or Mechanical frequency?
To convert a frequency to a voltage, you need an electronic frequency (voltage varying in time).
One can use different types of transducers to get an electronic frequency from a mechanical one.
National makes a chip, LM2917, just for this application. Check out http://www.national.com/mpf/LM/LM2917.html" where you can see the transducer (magnetic pick up).
sensor transduces electrical frequencies?
how to convert this frequency to mechanical frequency(RPM),,,
i ve seen a design before, they use scmitt's trigger before f to V converter
generator--->trafo---->scmitt's---->LM2917---->PLC---->inTouchwonderware
i think schmitts don't sense the frequency...(no magnetic pick up)?
LM2917 only detect positive peak of sinusoidal wave?
http://www.imagehosting.com/out.php/i1447796_all.jpg
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
