Fortran How to Merge and Sort Two Fortran Arrays?
  • Thread starter Thread starter hobmarcus
    Arrays Fortran
To merge two arrays and sort them in ascending order, a new array should be created with sufficient size to hold all elements from both arrays. A loop can be used to transfer elements from the first array into the new array, followed by another loop to add elements from the second array, starting at the index where the first loop ended. For finding the intersection of the two arrays, a separate subroutine is required. This involves comparing each value in both arrays and storing the intersecting values in a new array, which may vary in size based on the data. It is important to provide code examples of what has been attempted for effective assistance. Additionally, posting in the appropriate forum section is recommended for homework-related queries.
hobmarcus
I have 2 set of data (from different files) and I allocate each set of data to array in my main program. But now I want to merge those 2 array and sort them in ascending orders in my sub program. What should I do? I know how to sort array in ascending orders, but i don't know how to merge those 2 array together... Any suggestion or help?
Technology news on Phys.org
pseudo code:
create new array big enough to hold all the data
create a loop that puts all of the first array's elements into the new array
create a loop that puts all of the second array's elements into the new array (starting at the index left at the end of the first loop)
phinds said:
pseudo code:
thanks you for answering my question. It helps a lot. However, Another subroutine is required to find the intersection of them and combined it into 1 array. Any suggestion or help please
You need to show us what you have tried. We are not going to write this code for you.
Your question should be posted in the Engineering & Comp. Sci. subsection under Homework & Coursework. I am closing this thread.
First, I tried to use do loop to compare each value in both array and the write out each intersect value. But I do not know how to put them together into an array since the size of this intersect array varies if the data change.
Again, you need to show us (in code) what you have tried, not explain to us what you have tried. As already noted, please start a new thread in the Homework & Coursework section.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
