Can Adding Resistors Prevent Overvoltage Damage to LEDs and Photodiodes?
  • Thread starter Thread starter _Bd_
    Component
Adding resistors before LEDs and photodiodes can effectively prevent overvoltage damage by creating a voltage drop, but proper circuit configuration is crucial. The user calculated resistor values of 370 Ohms for the photodiode and 175 Ohms for the LED based on desired current and voltage drops. Issues in simulation software like MultiSim may arise from incorrect connections or misunderstandings of circuit components, such as grounding and voltage sources. It's essential to ensure that the components are connected correctly to allow current flow through the resistors. Proper setup and testing will help confirm if the proposed solution will protect the components from damage.
_Bd_
So I am looking at my spec sheets, I am running most of my boards on 5V (Arduino)
There are however 5 LEDs that say can have a maximum FV of 1.5V, so I am pretty sure they will fry if I run the 5V through them, there are also 5 Photodiodes that have a 1.3 maximum FV, so they will fry as well.
What I was thinking is connecting them all to my VCC, but to add a resistor right before the actual component, which would create a voltage drop. (I am not sure if this would work though)
So I am thinking of doing this:
http://img12.imageshack.us/img12/1894/una0.png
Now I am not sure if this will work, I tried setting that up in MultiSim, but it didnt show any voltage drop across the resistor, it kept saying the Voltage going to the PD and LED were still 5V which I really want to avoid.
I calculated this using the following:
Knowing the current and voltage for the PD
10 mA, and 5V, I want a drop of 3.7V, so V=iR
so that gives a resistor of 370 Ohms for the Photodiode, and using the same logic a Resistor of 175 Ohms for the LED.
Will this work? or will my components still fry?
Thank you for all your help
That's a sensible way to do it, and you seem to have calculated the resistor values correctly.
I don't know why it didn't "work" in Multisim. Did you have the diodes the wrong way round in your input? Or are you misinterpreting the output somehow?
Cut the problem down to the minimum, and simulate just a resistor, a diode, and a 5V voltage source.
yeah well, In multisim I just did the resistor, the diode and the source, and where I think the problem might be is that I connected the other lead to ground? since I didnt know what to put there (I didnt want to completely re-draw my circuit, which I just showed in that picture as a "black box")
I'll try it again and upload some screenshots, but it was pretty much that same picture up there but with ground instead of the black boxes.
Or maybe it was that I listed it as VCC? (I am not sure, but it says vcc are TTL sources, i don't know if maybe a CMOS source? or what type of source should I use? or does it even matter, just for the multisim schematic?)Anyways, Thanks, ill try it like so and hopefully i won't fry my components
it would depend on what the connection in the "black box" is that the LED is being connected to
ie. is it a current sink -- that point is grounded when an operation occurs therefore allowing current to flow from 5V through the resistor and LED to ground
or is it a current source ?, which will require the LED to be reversed and going to an external ground via the resistor
Only you can tell us what is occurring in your "black box"
Dave
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
