How to overcome heating due to friction
  • Thread starter Thread starter ahmed11
    Friction Heating
Converting heat generated by a drilling machine into useful energy without using drilling fluid presents significant challenges. The primary methods of heat transfer, conduction and radiation, are inefficient for this purpose, making it difficult to harness the heat effectively. While theoretically possible to convert heat back into mechanical energy, the practicality and efficiency of such a process are questionable. High-temperature reservoirs may allow some heat recovery, but the low-grade nature of the recovered heat limits its usefulness. Overall, there are currently no effective solutions for this problem in drilling operations.
ahmed11
If I am rotating an object into the ground ( drilling machine) how can i convert all the heat into something useful without wearing the drilling machine? without using drilling fluid to cool it down. like should i use certain materials that can resist the heat from friction or can i like use the heat from the outer surface of the object and convert it into energy without damaging the object itself?
sorry if the question is stupid but i really need help
Science news on Phys.org
DaleSpam said:
This would require a cooling source (cold reservoir) at absolute 0.
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/carnot.html
i get what your saying but if its a high temp reservoir, could i convert this heat of friction AWAY from the drilling machine and use it?
Without using a fluid to transport the heat you are limited to conduction in the drill itself and radiation. Both of those mechanisms can be used for heat transfer, but they are very slow. That is partly why fluids are usually used.
Likes ahmed11
By something useful, I assume you mean mechanical energy. So, you are converting mechanical energy from your drill into heat, and now you want to convert the heat back into mechanical energy. Why bother. Also, doing this on a practical basis would not be worthwhile.
Chet
Likes ahmed11
This is an age-old problem and unfortunately there are no good solutions. Eliminating friction to preserve cutting tool life reduces cutting effectiveness and either way, the heat of friction that can be recovered is generally too low grade to be useful.
Likes ahmed11
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
