How to prove a function is vector valued
  • Thread starter Thread starter friend
    Function Vector
To prove a function f is vector valued, it is essential to show that its output can be expressed as a combination of multiple functions, such as f = (f1(x,y), f2(x,y)). The co-domain of f is determined by its definition, and it is assumed that f1 and f2 are real-valued functions with inputs from the vector space R2. For f to be complex valued, it must be shown that f = f1(x,y) + if2(x,y), where f1 and f2 are real-valued. The requirement for f1 and f2 to be real-valued is crucial, as demonstrated by counterexamples where the output does not meet the criteria. Understanding these definitions and properties is key to establishing whether a function is vector or complex valued.
friend
Suppose you have a function f. Perhaps its input is one variable, f(x), or maybe its input is two variables, f(x,y). How can you prove that the function is itself vector valued,
f=(f1(x,y),f2(x,y))?
Or perhaps it would be easier to prove that f is a complex valued function,
f=f1(x,y)+if2(x,y).
Mathematics news on Phys.org
All I can say is that the way it is defined tells what the "co-domain" is. I presume you are assuming that f1(x,y) and f2(x,y) are themselves real-valued and that (x, y) is a member of the vector space R2. However, R2, alone, is not "given" as a vector space. You would have to assume, or be given, the standard definitions for sum of two pairs and scalar multiplication.
Similarly, if f1(x,y) and f2(x,y) are real valued, then f1(x,y)+if2(x,y) is, by definition, a complex number for every (x, y). (The requirment that f1 and f2, separately, be real valued is necessary. For example, if f1(x, y)= x+ y and f2(x, y)= i, f(x,y)= f1(x,y)+ if(x,y)= x+ y- 1 which is real valued.)
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
