How to prove units when you have logs in an equation
  • Thread starter Thread starter gtbiyb
    Units
When dealing with logarithmic equations, the units involved typically become dimensionless, as logarithms are defined for ratios. In the example provided, the transformation to find pressure P involves using natural logarithms, which complicates unit proof. The discussion highlights that while the original equation may have been misremembered, the final transposition appears valid for calculating P(0). Participants emphasize that any constants or additional units must be considered to ensure dimensional consistency. Ultimately, the challenge lies in proving units when logarithmic functions are involved, as they inherently simplify to dimensionless forms.
gtbiyb
Hi,
What happens when, following a numerical calculation, you have to prove the units but the equation has logs?
For example:
ln P = (ln z1 - ln z2)/(z1 - z2)
So as the RHS will simplify to a number when all values are known you end up with:
ln P = x, x being some value
so to find P you now have to:
e^x = P
I now the units turn out to be Pa as its pressure but how to prove it!
Cheers
Matt
when logs are involved the units of measure would be dimensionless except if the units of measure were based on a log definition like decibels.
A similar example would be using radian measure in trig functions what's the unit of measure of sin(alpha) as in the equation:
(length of hypotenus in meters)*sin(alpha) = (length of opposite side in meters)
sin(alpha) its dimensionless right?
Yeah i see that thanks, i have also just read that in e^x the x has to be dimesionless. But my answer should be a pressure in Pa! I transposed a formula to get that above but am confident its valid.
Your original equation looks a bit strange to me, where did it come from?
If you rearrange it I get...
lnP = (lnz1 - lnz2)/z1 - z2
i.e lnP = ln(z1/z2)/(z1-z2)
i.e (z1-z2)lnP = ln(z1/z2)
i.e P ^(z1-z2) = z1-z2
Is this what you started with ?
Revise the way you have obtained your formula. May be you solved a diff. equation, and a constant has been lost?
Thanks guys,
So i have put thought into this in general but in other situations the units cancel as the log is taken of a ratio but in this case i have basically a simultaneous equation:
P(z1)=P(0)e(-z1/λ)
and
P(z2)=P(0)e(-z2/λ)
I know P(z1), P(z2), z1 and z2
I want to know P(0) So i transpose both to eliminate λ thus:
ln P(z1) - ln (P(0)) = -z1
so
λ= -z1/ln P(z1) - ln (P(0))
Therefore:
z1/(ln P(z1) - ln (P(0)))=z2/(ln P(z2) - ln (P(0)))
Simplifying to get:
(z2ln P(z1)-z1ln P(z2)/(z2-z1)=ln (P(0))
What do you think?
I can see the original equation i put down was wrong as i was doing it from memory and it was the general theory i was after! The above is correct though.
Matt
Anyone got any advice on this?
I think we already answered your question. You can't do units math when log and trig funcs are used. The exception being when a measurement is log based such as decibels.
http://en.wikipedia.org/wiki/Decibels
But what do you do then to prove the units in the example i gave, I'm sure my transposition is correct.
do the units work out when you treat the log funcs as dimensionless?
also you could be missing a constant that provides some additional units for cancelling out
like the G in the classical Gm1m2/r^2 gravity formula the result is the force so the G must have units
that cancel out so the resultant answer is in Newtons.
Gtbiyb, though ln(P) looks unaccustomed for me, I think you are right, and the formula can be applied for calculations. Both of its parts has the same dimension. If one applies exp to the both of the parts of the formula it will be obtained P0=P(z1)^(z2/(z2-z1))/P(z2)^( (z1/(z2-z1)). I’m not sure it is a better form.
