How to pulse electric a current
To pulse an electrical current through a circuit, using a 555 timer chip is recommended, particularly in an astable multivibrator configuration. The frequency of the pulse can be adjusted based on the components used, such as relays, with a suggested starting frequency around 20Hz. For beginners, experimenting with the 555 timer allows for control over pulse speed, similar to flashing Christmas lights. Additional resources, including books and online articles, can provide further guidance on using the 555 timer effectively. Overall, the 555 timer is a suitable choice for creating adjustable pulsing circuits.
balbert99
How to "pulse" electric a current
I'm looking for a way, or component, that will pulse an electrical current through a circuit, and I'm not sure where to start looking. I'm looking to hook a 9v battery to a small simple circuit and send the current through that circuit in pulses. For example on-off-on-off.
Try looking at IC 555 timer chip circuits. What you want is an astable multivibrator.
It would help a lot to describe the frequency of the pulse. Please be specific to get an educated guess. Don't expect an exact answer but one that will point you in the right direction.
After reading your question closer, one thing I could do is make a multivibrator out of two nine volt DC relays. The multivibrator frequency would be determined by the RL of the relays. I have never tried this but would give a guess at 20HZ? The frequency depends on the RL circuit and the larger the relays the slower it would flip-flop. But if all you want to do is use a simple 555 timer then go for it.
Thanks guys for the help! I'm new to this, and find it very interesting. I don't think I know enough to answer your questions with a lot of detail. What I'm imagining is a circuit similar to (but not exactly like) a string of flashing christmas tree lights. Some strings give you the ability to set their speed: slow, fast, or solid/no flash. Since I'm new to this, I'd like the ability to adjust the speed the "pulses" travel through the circuit to see how things react at different speeds: slow, medium, fast, etc. From what I've read, the 555 timer would be a good start.
Any books or on-line articles you can suggest would be great too! Thanks again!
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
