How to put magnetic field in the wave equation
fabsuk
Could someone please help, i think this is gauss's law but I am not sure how to answer it as they give me a wave equation and i don't know how to put magnetic field in as well. Help would be much appreciated
Question
suppose that an appropriate device is used to genereate an osccilating electric field in a limited region of the xy plane of a Cartesian Reference frame ,as described by
E(r,t) ezE0sin(wt) for
√x(squared)+Y(squared) <(equal ) R
a) determine the expression for the magnetic field induced by this electric field in the xy plane at a distance r<R from the origin
b)at a distance r>R from the origin assuming that in the 1st approximation E=0 in this region
c) discuss if u would expect an induced an electric field to also be present in the region r>R of xy plane
Hi fabsuk,
You need to take a step back from the wave equation and look directly at the Maxwell equations. You know the electric field in some region and you want to find the magnetic field. This is will be possible because Maxwell's equations relate the two fields.
Try to make some progress with this hint, and let me know how you do.
yes but why do they give me an equation of a circlr
delta cross E= - db/dt
can't do it
i don't know what to differentiate E with respect to
i know the answer is 0 outside sphere but inside sphere i am clueless.
please help.
fabsuk said:
can't do it
please help.
Physics Monkey already gave you a clue :smile:. Use Maxwell's relation for the electric and magnetic vectors. OK here goes: If E and B represent the magnitude of the electric and magnetic fields respectively:
{E\over B} = c = {{1\over \sqrt{\epsilon_o \mu_0}}
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
