I How to select gear/sprocket ratios for vehicle?
  • I
  • Thread starter Thread starter Thathrooban
    Ratios Vehicle
The discussion focuses on selecting gear and sprocket ratios for a vehicle weighing 150kg, powered by a 12kW motor with 27Nm torque and 110/80 R17 wheels. Participants emphasize the importance of calculating the wheel's radius for accurate transmission calculations, clarifying that the tire specification provides sufficient data for this. An example illustrates how to derive the wheel's diameter and radius, impacting the force exerted on the ground and subsequent acceleration. The calculations show that with no gears, the vehicle would accelerate at 0.429 m/s², leading to a potential speed increase of 1MPH per second. The conversation concludes with a need for clarification on the units of acceleration, highlighting the technical nature of the topic.
Thathrooban
The mass of vehicle with driver is 150kg. The specification of motor are 12kw, 27Nm torque, using 110/80 R17 wheels . 1. what is the general consideration to do transmission calculations of bikes 2.How to select gear ratios and sprocket ratio?
"110/80 R17 wheels ." ... This does not help we need to Know the RADIUS of wheel , including tire.
110/80 R17 is enough information to calculate the radius/diameter; the 110/80 is a tire specification even though OP said "wheel".
Likes Thathrooban
I think the below example will be clear you doubt on calculating radius.
Example: 285/75R16 (285 X 75 / 2540 x 2) + 16 = 32.8 inches tall.
I guess 'tall' means dia?? ... In which case we have a radius 0.42 meters
We are told the torque is 27Nm which means if the wheel had a radius of 1 meter , it would push horizontally on the ground with a force of 27 Newtons ...
and this would be the force accelerating the bike and passenger ... but the wheel is smaller and so we get more force ... 27/0.42 = 64.3 Newtons
Since the mass is 150kg , the acceleration is ... F=ma ... 64.3/150 =0.429 m/sec
1MPH = 0.45m/sec
So that's the acceleration with no gears ... an increase of 1MPH every second ... it would take you 20 secs to reach 20MPH !
You need to decide what is an acceptable acceleration 5MPH increase every second would need a 5 to 1 gear... that's 0 to 30MPH in 6 secs
If you want to reach 30MPH in 3 secs , that's an accn, of 10MPH/sec ... a 10 to 1 gear is needed .
The 0.429 is acceleration you put it as m/sec how? i can't able to get it.
It's m/s2.
A.T. said:
It's m/s2.
yeah that's why I ask him.
Thread closed pending moderation.
