How to Solve a Tricky Integral: Step-by-Step Guide for Beginners
  • Thread starter Thread starter ISU20CpreE
    Push
ISU20CpreE
ok i got this problem:
\int\frac{\sqrt{x-2}} {x+1} \,dx
then i have to let u=(x-2)^0.5 then i solve for x in terms of u
so i get x= u^2+2
dx=2u du
\int\frac{\sqrt{x-2}} {x+1} \,dx=\int\frac{u}{u^2+3}\,2u\,du
where when i substitute i get:
\int\frac{2u^2} {u^2+3}\,du. after that I am completely lost.
Maybe:
Pull the 2 out, then add 0 to the top (+3 - 3). Then, can you solve: 2\int\frac{u^2 + 3 - 3} {u^2+3}\,du
Try making u = x+1
mattmns said:
Maybe:
Pull the 2 out, then add 0 to the top (+3 - 3). Then split the fractions and easy.
what if i do this
\frac{2u^2}{u^2+3}=2-\frac6{u^2+3} i do polynomial long division. lol. but then what??
cyrusabdollahi said:
Try making u = x+1
It will be easier but the book says i have to use the other one.
what if i do this
Then it's cool. The first time is easily integrable. The second term has a solution as well.
Edit: Integrating the second term will be easier with substitution u = a\tan y, and the identity \tan^2 x + 1 = \sec^2 x
Did you see my edit? I think that is really easy to solve. No polynomial division needed :smile:
how is that helpful?
Split that up into two parts:
(a+b)/ c = a/c + b/cSo,
2\int\frac{u^2 + 3 - 3} {u^2+3} du = 2(\int\1du - \int\frac{3}{u^2+3}du)
Which is easy to solve, unless I made some silly mistake.
mattmns said:
Maybe:
I am confused with differnent methods sorry I've been trying for a few hours. I don't know what to do.
Gotcha mattmns, your right that is easier.
looking at my table of integrals:
\int \frac{dx}{x^2 + a^2} = \frac {1} { a} tan^{-1} ( \frac{x}{a} ) + C
where x is your u, and a is square root of 3.
so if i will get as an answer this??
2u-6\frac{1} {\sqrt{3}} tan^-1\frac{u} {\sqrt{3}},+c
change all your U's into \sqrt{x-2}, and you can anwser your own question, if we did this right, take the derivative, do you get the question you were asked in the beginning? That is always a good check to do when your not certain.
You are totally right my friend, but in the book it gives me this answer
2\sqrt{x-2}-2\sqrt{3}\tan^{-1}\left(\sqrt{\frac{x-2}3}\right)+C
hmmm the inner part of the ( ) looks good, some how I goofed off the 2 (3)^.5 part let me see.
nope were still fine, just multiply top and bottom by square root of three. so that you go from \frac { 6} { \sqrt 3 }
to
\frac { 6 \sqrt 3} { ( \sqrt 3)^2 }
and you get
2 \sqrt {3}
LoL, no problem thanks. Thank you very much for the help.
I see i really needed it
