How to solve for f_n(x) in Stewart Calculus text's review section?
  • Thread starter Thread starter Jeff Ford
    Function Stuck
To solve for f_n(x) in the Stewart Calculus review section, the relationship f_0(f_n(x)) = f_{n+1}(x) is established, starting with f_0(x) = x^2. The discussion reveals that f_1(x) = x^4, f_2(x) = x^8, and continues with a pattern suggesting f_n(x) = x^{2^{n+1}}. However, there is confusion about whether this holds true for f_0(x) = x^2, leading to a realization that the initial conditions may have been misinterpreted. Ultimately, the conclusion is that the derived formula needs to be consistent with the base case.
Jeff Ford
I'm going through the review section of the Stewart Calculus text and I'm stuck on this problem.
Given
<br /> f_0(x) = x^2<br />
and
<br /> f_0(f_n(x)) = f_{n+1}(x) , n = 0,1,2...<br />
how do you solve for
<br /> f_n(x)<br />
The only place I can think to start is making (f_n(x))^2 = f_{n+1}(x), but that's as far as I got
Now, f1(x) = f0(f0(x)) = f0(x2) = x4
f2(x) = f0(f1(x)) = f0(x4) = x8
f3(x) = f0(f2(x)) = ...
f4(x) = f0(f3(x)) = ...
So what's fn(x)?
Can you go from here?
Viet Dao,
From that I get f_n(x) = x^{2^{n+1}} but that doesn't work for f_0(x) = x^2. That's the same answer the book has, so maybe I wrote the requirements down wrong. I'll have to check when I get home if this had to work for 0.
Yes it does. Never mind.
Thanks Viet Dao!
