How to Approach Solving a Nonlinear Second Order ODE with a Quadratic Term?
Safinaz
How to solvebthis second-order ODE:
\frac{\partial^2 x}{ \partial t^2} + b \frac{\partial x}{ \partial t} + C x - D x^2 =0
Or:
\ddot{x} + b \dot{x} + C x - D x^2 =0
Where
## b, C, D ## are constants.
I know how to solve similar ODEs like
\frac{\partial^2 x}{ \partial t^2} + b \frac{\partial x}{ \partial t} + C x =0
Where one can let ## x = e^{rt}##, and the equation becomes
r^2 + b r + C =0
Which can be solved as a quadratic equation.
But now the problem is that there is ##x^2## term, so if one used that substitution, we left by:
r^2 + b r + C + D e^{rt} =0
So any help to find the solution of the ODE
Safinaz said:
Where one can let x=ert, and the equation becomes
r2+br+C=0
You have got general solution of homogeneous differential equation. Then you have to find a particular solution to add that for inhomogeneous differential equation with x^2 term. Have you investigated x=constant ?
anuttarasammyak said:
You have got homogeneous general solution. Then you have to find a special solution to add that. Have you investigated x=constant ?
The OP's equation is a non linear ODE?
My bad. Thanks. By choosing sign of constants, the equation is interpreted as oscillation of a body in a viscous medium with harmonic if D=0 and inharmonic with D potential. x = 0 is stable, x= C/D is unstable point for small oscillation around.
Safinaz said:
##\frac{\partial^2 x}{ \partial t^2} + b \frac{\partial x}{ \partial t} + C x - D x^2 =0
Or:
The second version of your DE, using the notation with dots, suggests that x is a function of t alone. In that case the first version of the DE should be written without partials.
Like so:
##\frac{d^2 x}{dt^2} + B\frac{dx}{dt} + Cx - Dx^2 = 0##
Also, since C and D are uppercase, B should probably be uppercase as well.
Yes. I'm sure your question was rhetorical.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
