fog37
- 1,568
- 108
Hello,
Certain power supplies can be both a voltage source or a current source.
a) Voltage source:
We set the voltage to a specific value we like and change load resistor. The current will vary (get smaller for larger R) but the voltage will not vary. To make the power supply a voltage source, I think we need to set the current knob to its maximum and the voltage knob to zero before turning to power supply on. Is that correct? Why?
b) Current source:
We set the voltage to a specific value we like and change load resistor. The current will vary (get smaller for larger R) but the voltage will not vary. To make the power supply a current source, I think we need to set the current knob to its minimum and the voltage knob to its max before turning to power supply on. Is that correct? Why?
One power supply I have seen has three terminals: positive, negative and ground. Which pair do we use when we want the power supply to be a voltage or a current source?
Thanks!
a) Voltage source:
b) Current source:
Thanks!
