How to use Thevenin to find R and I?
The discussion revolves around using Thevenin's theorem to analyze a circuit involving a variable resistor R that is consuming maximum power. Participants are attempting to determine the resistance for R, the power for R, and the current and direction for R3. The conversation includes various calculations and interpretations of circuit behavior.
  • Homework-related
  • One participant calculates the direction of current IA using an equation but expresses uncertainty about its correctness.
  • Another participant suggests investigating the "Maximum power transfer theorem" and proposes that R equals the Thevenin resistance RT.
  • Several participants calculate the current IA and voltage Uab using different approaches, with some arriving at different values for Uab, leading to confusion.
  • Discrepancies arise regarding the values of Vth and Uab, with participants debating whether Uab can be considered equal to Vth after a load is attached.
  • One participant questions how the maximum power transfer theorem applies when different values for IA and Uab are obtained.
  • Clarifications are made about the relationship between Thevenin voltage, load resistance, and the resulting voltage across the load.
Participants exhibit disagreement regarding the correct values for Uab and the application of Thevenin's theorem, with no consensus reached on the calculations or interpretations presented.
There are unresolved issues regarding the assumptions made in calculations, particularly concerning the effects of load resistance on voltage readings and the application of the maximum power transfer theorem.
This discussion may be useful for students and practitioners interested in circuit analysis, particularly those studying Thevenin's theorem and the maximum power transfer theorem in electrical engineering contexts.
stipan_relix
In the circuit shown, in the image, the variable resistor R is consuming maximum power. Determine:
a) resistance for R
b) power for R
c) current for R3 and its direction
I tried getting IA(the direction is shown with arrows in the picture under) like this: E1-IAR3+IR3-IAR4=0
-5IA-5IA=30-10
IA=-2 A
but I have a feeling that's not good ^
I calculated RT using Thevenin: RT=Rab=R3+R4=10Ω
Then I got from the main scheme:
Uab=-IAR4+E1-IAR3+IR3 = -(-2)*5+30-(-2)*5+10 = 60 V
I don't know how to proceed now.
Investigate the "Maximum power transfer theorem".
So according to the "maximum power transfer theorem", R=RT=10Ω. Thank you.
From that, the equation for IA should be:
E1-IAR3+IR3-IAR-IR-IAR4=0
-20IA=-30-10-20
IA=3 A
and for Uab:
Uab=-IAR4+E1-IAR3+IR3=40 V
Now I can get IR=ET/RT+R=2 A and PR=I2*R=22*10=40 W. Hopefully I did everything right.
Although, now it asks me to get IR3 and its direction, but isn't its direction already defined by the current source?
Maybe it's: IR3=I+I-IA ? With direction to the left?
-20IA=-30-10-20
IA=3 A
and for Uab:
Looks good. A simpler way would be to employ your Thevenin equivalent:
##I = \frac{V_{th}}{R_{th} + R_L}##
##V_{ab} = V_{th} \frac{R_L}{R_{th} + R_L}##
Not quite, since neither of the current sources is directly in series with ##R_3##, and you may not be able to know off hand the effect of ##E_1## on the direction. However, you do now know all the currents but one entering/leaving the central node, so KCL at that node will settle the matter.
Yup.
Looks good. A simpler way would be to employ your Thevenin equivalent: Vab=Vth*RL/Rth+RL
This gives me Vab = 20V, but my way above got Vab = 40V?
Oops, I missed that when I scanned your work. Although you shouldn't be getting 20 V either !
By the Thevenin method you know you've got a voltage divider with two equal resistances, hence the output should be 1/2 the source voltage, so one half ##V_{th}## or 30 V.
I am confused now. Isn't the Vab I got also Vth? Where did you get 30 V from?
See the diagram in post #5.
You calculated ##V_{th} = 60\;V## and ##R_{th} = 10\;\Omega##. Half of ##V_{th}## is ##30\;V##.
It says 40V for me, not 60V?
I also thought Vab = Vth?
In your very first post you correctly calculated the open circuit voltage ##U_{ab}## which is the Thevenin voltage. Once you attach a load across the output, it will no longer read ##V_{th}## but some fraction of it depending on the size of the load resistance and ##R_{th}##.
Alright, but how does that fit into the maximum power transfer theorem if RT=R=10Ω then gives me IA=3 A and with that IA I get Vab=40V?
Because the first time I solved for IA, I did it like R wasn't there at all, but since RT=R=10Ω, shouldn't I solve it using R in the equation as well?
Yes. For the Thevenin version you've two resistors forming a voltage divider. Each of them is 10 Ω. Also,
3 A * 10 Ω = 30 V.
Okay I think I kind of understand it now. Thank you.
  • · Replies 35 ·
  • · Replies 28 ·
