How to Structure a Scientific Report with Multiple Experiments?
  • Thread starter Thread starter hhhmortal
    Report Scientific
hhhmortal
I know there's the following sections:
Abstract
Introduction
Method Used
Results
Data analysis
Discussion
Conclusion
Awknowledgement
References
But when there are two areas of the experiment to be investigated, say measuring the wavelength of light for green and yellow using diffraction gratings, do you talk about them in these headings, or do you create these headings again for each part of the experiment?
Thanks.
Of course I don't know exactly what your experiment looks like, but it would seem logical to me that you have two separate sets of results for green and yellow. So I would make subsections "Green" and "Yellow" in the results and data analysis section. The method used is probably the same for both, isn't it? Also, in the discussion and conclusion, you probably don't need two different sections. It can look like: "The data from section ... show that green light is a primary color on most computer displays, while we have shown in table ... from section... that yellow is not" - e.g. you can mix it into one running story.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
