How will things change after irrelevant operators are confirmed?
  • Thread starter Thread starter Physics Monkey
    Change Operators
Physics Monkey
I want to consider a thought experiment:
Suppose, at some point in the near future, the effects of irrelevant operators in the standard model are firmly confirmed by experiment. In other words, we see some effect, perhaps the muon g-2, which simply cannot be accounted for without including some higher dimension operator.
How will the discussion of BSM physics change? Does naturalness become an even greater issue?
Good question. I suppose the scale at which you expect this to happen is quite large though(?). The energy scale at which the fine structure constant approaches one. It is interesting that the reason we consider only relevant operators has changed since the 70's. Originally is was supposed that only renormalizable term were included in order for the theory to make sense. However now we know that, when viewed as an effective theory, all terms can be renormalized and therefore the reason we observe only renormalisable terms is that they are the only ones which are relevant at low energies.
I think if we observed some higher order operators we would then have to find a way of predicting (or postdicting) the value of the coupling. This could either come from some new physics (e.g. string theory) or an asymptotic safety scenario for the standard model.
It's not clear to me that the scale of new physics needs to be so large. I guess I don't have much of a sense of the data and constraints. Is a new particle, say a new fermion, with mass above 1 TeV ruled out? Or 10 TeV?
Suppose I think the "desert" scenario and susy are just crazy and that its probably complicated physics all the way from 1 TeV to the Planck scale. Is it crazy to imagine that we just happen to be sitting at a point in the energy landscape where irrelevant operators are fairly small?
Did one of the ways to model Neutrino mass involve irrelevant operators?
Thread 'LQG Legend Writes Paper Claiming GR Explains Dark Matter Phenomena'
A new group of investigators are attempting something similar to Deur's work, which seeks to explain dark matter phenomena with general relativity corrections to Newtonian gravity is systems like galaxies. Deur's most similar publication to this one along these lines was: One thing that makes this new paper notable is that the corresponding author is Giorgio Immirzi, the person after whom the somewhat mysterious Immirzi parameter of Loop Quantum Gravity is named. I will be reviewing the...
I seem to notice a buildup of papers like this: Detecting single gravitons with quantum sensing. (OK, old one.) Toward graviton detection via photon-graviton quantum state conversion Is this akin to “we’re soon gonna put string theory to the test”, or are these legit? Mind, I’m not expecting anyone to read the papers and explain them to me, but if one of you educated people already have an opinion I’d like to hear it. If not please ignore me. EDIT: I strongly suspect it’s bunk but...
https://arxiv.org/pdf/2503.09804 From the abstract: ... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
