How would one label power? Is it in Newtons?
  • Thread starter Thread starter scienceiscool
    Newtons Power
Power is measured in Watts, which is defined as one Joule per second or one Newton meter per second. When discussing a car balanced on a hill, the two primary forces acting on it are gravity, which pulls the car downward, and the normal reaction force from the ground, which pushes upward. Inertia does not act as a separate force in this context; rather, it describes the car's resistance to changes in its state of motion. The discussion clarifies the relationship between power, work, and force, emphasizing that power is not measured in Newtons. Understanding these concepts is essential for analyzing forces and power in physics.
scienceiscool
How would one label power? Is it in Newtons? And also, if a car is balanced on a hill, what are two of the forces that are acting upon it. I have gravity of course, but does inertia also work? Thanks in advance!
How do you call the force of this hill on the car?
about power: recover the units yourself knowing that power is work per unit time and work is force times distance.
balanced forces? j/s or Watts?
It's in Watts.
1 Watt = 1 Joule per second = 1 Newton metre per second.
There's the force of the Earth pulling down on the car (i.e. gravity, or the weight force), and the force of the ground pushing up on the car (usually called the "normal reaction force").
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
