How would you have done this Coulomb's law problem?
  • Thread starter Thread starter 1MileCrash
    Coulomb's law Law
To solve the Coulomb's law problem involving three charged particles, the net electrostatic force on particle 3 must be zero, which requires it to be positioned to the left of particle 1 due to the stronger negative charge of particle 2. The calculations show that the y-coordinate of particle 3 is zero, allowing for the cancellation of forces in the y-direction. The derived x-coordinate for particle 3 is approximately -13.66, aligning closely with the book's answer of -14. The discussion highlights the importance of understanding vector directions and magnitudes in electrostatic problems. Overall, the method used to find the coordinates is validated, and the reasoning behind the y-component being zero is clarified.
1MileCrash
In the figure, particle 1 of charge 1.0 micro Coulombs and particle 2 of charge -3.0 micro Coulombs are held at a separation of L = 10.0 cm. If particle 3, of unknown charge is to be located such that the net electrostatic force on it is 0, what must its x and y coordinates be?
(figure)
1<------L------->2
with 1 at the origin.
Coulomb's law
First, I noted that the particle must be to the left of 1 because 2 is of stronger net charge, so it must be closer to 1 and further from 2.
Furthermore, since the sum of the two forces is 0, they must be equal in magnitude and opposite in sign.
kq_{1}q_{3}r^{-2}_{1}\widehat{r}_{1} = - kq_{2}q_{3}r^{-2}_{2}\widehat{r}_{2}
q_{1}r^{-2}_{1}\widehat{r}_{1} = - q_{2}r^{-2}_{2}\widehat{r}_{2}
I was stumped here until I cheated and looked at the y coordinate answer. It is 0. Only knowing that was I able to solve. Can someone tell me why that is the case?
Since I know the y coordinate is 0, the vectors on both is -i, allowing me to cancel them out.
q_{1}r^{-2}_{1} = - q_{2}r^{-2}_{2}
(1x10^{-6})r^{-2}_{1} = (3x10^{-6})r^{-2}_{2}
r^{-2}_{1} = 3r^{-2}_{2}
r^{2}_{2} = 3r^{2}_{1}
r_{2} = \sqrt{3}r_{1}
I also know that r2 is 10 greater than r1.
r_{2} = 10 + r_{1}
Substituting that for r2 in the first equation,
r1 = 13.66.
Since I know it's to the left of r1, and r1 is on the origin, the x coordinate must be -13.66.
The answer in the book is -14, so I'm reasonably confident.
However, I want to know:
1.) Is this how you would have done it?
2.) Why is the y component 0?
3.) Is the y component known to be 0 through working the problem, or from examining the layout of the particles?
TY
Hint: Can two non-parallel vectors cancel?
Nope, I see. Thanks.
does the rest look ok?
I didn't check your arithmetic, but your method is perfectly correct.
