Is it safe to use electricity on the human body for muscle reflex studies?
The discussion centers on the safety and technical considerations of using electricity on the human body for muscle reflex studies. The user aims to create a circuit that delivers 200-500 microA of current, primarily using DC for consistent direction. Concerns about safety regulations and the necessity of proper electrodes are emphasized, with recommendations to consult faculty advisors for guidance. The importance of using medical-grade electrodes instead of dry contacts is highlighted to ensure safety and reliability in readings. The thread is temporarily locked pending further discussion on safety measures.
flam3_s33k3r
Hello,
I want to build a circuit that can put about 350 microA in my body(to study muscle reflexes etc.). Until now I've come to the conclusion that I need DC in order to get a definite direction of the current. Can anyone help me in figuring out what kind of AC/DC transformer and what output should my circuit have? I also what to be able to modify the desired current between roughly 200-500 microA.
flam3_s33k3r said:
Hello,
Welcome to the PF. Exactly what are you trying to do? How familiar are you with safety considerations when combining electricty and the human body?
I am a 2nd year student in Computer Science. This week I will consult my faculty teachers as well. I am familiar with some safety regulations but only for voltage sources. As I stated above I wish to drive a 200-500 microA current through certain areas of my body(varying accordingly with the muscle lengths of the body). This will happen with two electrodes (copper probably) touching the skin (dry, with no inductive materials applied). I will try to get some readings for my body's resistance using a multimeter. I have a 220-230V (50 Hz) AC input and I need to figure out an approach to build my circuit.
Hopefully your advisor is familiar with biomedical safety regulations, and can make that part of your study for this project. Are you looking to do some electromyograms?
http://en.wikipedia.org/wiki/Electromyography
You will not get consistent results with dry contacts. You will need to use traditional medical electrodes (disposable, stick-on type). And be careful -- when you start making good electrical contact with the body with those electrodes, you open yourself (and others) up to some potential dangers.
I think you should meet with your advisor and discuss safety a bit before trying anything out. Especially something you read on a web forum. I'm going to lock this thread for now. PM me after you've met with your advisor, and tell me what kind of safety considerations you've been studying and have discussed, and I'll consider re-opening the thread.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
