HVDC Back-to-Back System Configuration: Explained
  • Thread starter Thread starter DUET
    System
The HVDC back-to-back system connects two AC systems directly without a transmission line, resembling two events occurring consecutively, hence the term "back to back." This configuration features two converters located at the same site, facilitating the transfer of power between the two AC systems. The analogy of "two games back to back" highlights the immediate connection between the systems. The discussion seeks clarification on the similarities between the diagram and the described configuration. Understanding this concept is crucial for grasping the operational mechanics of HVDC systems.
DUET
The above diagram is for HVDC back to back system. My question is why do we call it back to back system?
Could someone please help me here?
It's a sports metaphor - like two games, back to back.
In this case it is because you see an AC system connected at one end, and another at the other end: back to back.
Could you please explain it? I am guessing "the two games happening immediately one after another. Correct?"
The simplest configuration is the back-to-back interconnection in which two converters are on the
same site without a transmission line.
Could someone please indicate the similarity between the bold part of the above sentence and the HVDC back-to-back system diagram above?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
