Hydraulic jack - Pascal's principle
DevonZA
Schematic of a hydraulic jack: a large piston of diameter D = 0.15 m carries a 500 kg mass, linked by a pipe to a smaller piston of diameter D = 0.05 m with force F applied on top.
P1=P2
P=F/A
F=PA
F1/A1=F2/A2
F2 = F1(A2/A1)
F2 = W(A2/A1)
W=mg
W=F*d
A1= pi/4 * d2 = pi/4 * (0.15)2 = 0.0177m2
A2 = pi/4 * d2 = pi/4 * (0.05)2 = 0.00196m2
P1=P2
P=F/A
F=PA
F1/A1=F2/A2
F2 = F1(A2/A1)
F2 = W(A2/A1)
W=mg
= 500 * 9.81
= 4905N
F2 = W(A2/A1)
= 4905 (0.00196/0.0177)
= 543N
1.1) Therefore the force of 500N cannot lift the 500kg mass because 543N is required to do so.
1.2) W=F*d
= 543 x 0.01
= 5.43J
W= F*d
5.43 = 4905 x d
d = 5.43/4905
d = 0.001m
= 1mm is the distance depressed.
  • Schematic of a hydraulic jack: a large piston of diameter D = 0.15 m carries a 500 kg mass, linked by a pipe to a smaller piston of diameter D = 0.05 m with force F applied on top.
I am confused. What is your question for us?
Your part 1 is correct. I am not sure what they want in 2nd part. Are they assuming that now you do have sufficient force and you push down a distance of 10 cm?
I only want to confirm that my answers are correct.
In 1.2 I believe they want to know the distance moved on the side of the mass when 10mm pushed down on the small piston side
Ratio = 0.0177/0.00196
= 9
Therefore ratio is 9:1
