Hydrogen bound by only grav force (Bohr theory etc)
kpou
If electric charge did not exist, and protons and electrons were only bound together by gravitational forces to form hydrogen, derive the expressions for a_0 and E_n and compute the energy and frequency of the H_alpha line and limit of Balmer series.
E_n=mc^2 * alpha * 1 / (2n^2)
E_n=-mk^2Z^2e^4/(2hbar*n^2)=-E_0Z^2/n^2
a_0=hbar^2/(mc*alpha)=hbar^2/mke^2
1/lambda=Z^2R(1/nf^2-1/ni^2)
If electric charge did not exist, then the balance of electron orbit and distance would change. Bohr's radius would just be zero i would imagine since it depends on electron charge. E_n would suffer the same fate... Would E_n just become mc^2? The radius would have to still be a number as the two do still have mass and gravity would affect them.
Edit:
F=Gm1m2/r^2 is the force on either exerted by the other and
E=-Gm1m2/r is the gravitational potential energy
The energy of the electron E_n must be strictly dependent on this.
How do I "derive" an expression from E_n or a_0 when their original formulas must be completely nixed?
Is there supposed to be a way of expressing it with n levels?
Otherwise I propose the energy of the electron is -Gm1m2/r as there is no kinetic energy.
One of the key components of the Bohr model is the electron's angular momentum must be an integer multiple of Planck's constant divided by 2 pi:
L = n h / 2 π . . . with n = 1, 2, 3, ...​
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
