Hydrolic Pressure and Bulk Modulus
3 replies · 7K views
vMaster0fPuppet
A solid copper cube has an edge length of 87.0 cm. How much pressure must be applied to the cube to reduce the edge length to 85.7 cm? The bulk modulus of copper is 1.4 multiplied by 1011 N/m2.
Vcube= s^3
F/A=(B x deltaV)/V
p=F/A
p=(B x deltaV)/V
V= (.870m)^3= .659m^3
Vn= (.857m)^3= .629m^3
deltaV= V-Vn= .03m^3
p=(1.4e^10N/m^2)x(.03m^3)/(.659m^3)= 6.37e^9N/m^2This is apparently not the answer?
Vcube= s^3
F/A=(B x deltaV)/V
p=F/A
p=(B x deltaV)/V
Is that 1.4 x 1010 Pa or 1.4 x 1011 Pa.
I think think it is 1.4 x 1011 Pa for copper as you originally gave in the problem.
Its 10^11, and I did the calculations with 10^11.
Thanks anyway, I actually figured the problem out. When I used .870^3-.857^3 for deltaV the calculations worked just fine. I didn't realize that making the calculation easier by breaking it up would cause such a problem if I used the correct number of significant figures.
OK then rightio. I didn't see a problem with your method.
