I can't figure this Trig Identity out help please?
The discussion centers on verifying a trigonometric identity from "College Trigonometry 5th Edition" involving the equation cos^2(x) - 2sin^2(x)cos^2(x) - sin^2(x) + 2sin^4(x) = cos^2(2x). Joe expresses frustration in solving the problem and questions whether it might be a misprint. A participant suggests using double angle formulas to expand the right-hand side, which leads to a successful verification. Joe ultimately resolves the identity by starting from the right side and applying various factoring techniques. The problem is confirmed to be solvable with the correct approach.
jtart2
I need to verify the given identity. I've tried every which way i can think of, but can't figure this one out. I am self-studying this book "College Trigonometry 5th Edition by Aufmann.
This is exercise set 3.3, problem 63.
Can anyone figure this out, or is this a misprint?
Thanks for your help,
Joe
Have you tried using the double angle formulae for cosine to expand the right hand side?
No Joe, it works out ok.
Start with cos^2 x - sin^2 x = cos 2x and square both sides. This gets you the require RHS straight up and most of the terms you require on the LHS too. You then need to do a bit more work (apply more trig identities to the terms that don't yet "fit") on the LHS and it comes out fairly easily.
Thanks, uart, I finally figured it out. I was starting on the left side instead of the right. After factoring and factoring and factoring it finally worked out! I've never factored so much in my life!
Joe
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
