How Fast Must the Enterprise Travel to Shorten 85 Light Years to 20?
  • Thread starter Thread starter hype_chicky
To shorten the distance from 85 light years to 20 light years, the starship Enterprise must travel at a significant fraction of the speed of light. The relevant formula for this calculation is l = l0√(1 - (v/c)²), where l is the contracted length, l0 is the proper length, v is the velocity, and c is the speed of light. By applying this formula, one can solve for the required speed (v) to achieve the desired distance contraction. This question highlights the fascinating implications of relativity in space travel. Understanding these calculations is essential for theoretical discussions on interstellar travel.
hype_chicky
the starship enterprise wishes to fly a distant glaxy 85 light years away. At what speed would it have to travel in order that the distance tot he galaxy would only be 20 light years...RELAVITY:( ..help if u caaaan thank yous
hmm
yes this is a rather intriguing question...i would love to see someone answer this one..any takers?
Have you seen the following formula:
l=l_{0}\sqrt{1-(v/c)^2}
You know both lengths and c, now just solve for v.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
