Is Water a Liquid in the Decomposition of Copper (II) Hydroxide?
  • Thread starter Thread starter honeyDew
    Reaction
The discussion centers on the decomposition reaction of copper (II) hydroxide (Cu(OH)2) when heated. It clarifies that the correct word equation for the reaction is that copper (II) hydroxide decomposes into copper (II) oxide (CuO) and water (H2O). The participants note that under proper heating conditions, water can exist as vapor, indicating it is a gas rather than a liquid. Observations during an experiment, including color changes while heating in a hot water bath, suggest chemical changes in Cu(OH)2, likely due to dehydration. The reaction can be represented as Cu(OH)2.nH2O(s) decomposing into Cu(OH)2(s) and nH2O(g). It is also mentioned that the release of water vapor typically occurs at temperatures around 185°C, which may not be achievable in a hot water bath. The discussion concludes with appreciation for the clarification provided.
honeyDew
I need Helps... Decomposition Reaction WE
is this how you're supposed to write a decomposition reaction in a word equation?
Copper (II) hydroxide decomposes with heat into the copper (II) oxide and water
...so then the water in this one would be a liquid right?
Chemistry news on Phys.org
Assuming it is under the correct temperature, the water will be water vapour, thus, a gas.
The Bob (2004 ©)
well we placed it into a hot water bath ...and constantly stirring it ... the color change so i guess it's gas ...right?
What changed colour? The water?
The Bob (2004 ©)
The colour change tells you that the Cu(OH)_2 has changed somehow chemically. Since the most likely change is dehydration that is what you should reasonably assume is what happened. Basically the Cu(OH)_2 was probably hydrated to some extent and what happened is that you have removed this crystal water by heating the hydrate. Cu(OH)_2.nH2O(s) \xrightarrow{heat} Cu(OH)_2(s)~+~nH_2O(g) describes this reaction.
When the Cu(OH)_2 decomposes it leaves CuO and H_2O. The H_2O will be released at temperatures of around 185^{o}C which is unlikely to be achieved in a hot water bath.
oh I see now...thank you so much for your helps :)
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
