I need some clarification Thermo Cycle
  • Thread starter Thread starter Saladsamurai
    Cycle Thermo
The discussion revolves around a thermodynamic problem involving Refrigerant 22 in a rigid tank, where energy is added via a paddle wheel and heat is lost to the surroundings. The user seeks clarification on the term "energy transferred in," questioning whether it refers to work done. They need assistance in calculating work and heat transfer, as well as determining a constant related to heat transfer. The problem involves specific initial and final states of the refrigerant, with no changes in kinetic or potential energy. The user is looking for hints to help them solve the problem effectively.
Saladsamurai
I need some clarification! Thermo Cycle
One kg of Refrigerant 22, initially at p1=.9MPa, u1=232.92 kJ/kG, is contained within a rigid closed tank. The tank is fitted with a paddle wheel that transfers energy to the refrigerant at a constant rate 0.1kW. Heat transfer from the refrigerant to its surroundings occurs at a rate Kt, in kW, where K is a constant, in kW/minute, and t is time in minutes. After 20 minutes of stirring, the refrigerant is at p2=1.2 MPa, u2=276.67 kJ/kG. No overall changes in KE or PE occur. (a) For the refrigerant, determine the Work and Heat transfer, each in kJ. (b) Determine the value of the constant K appearing in the given heat-transfer relation in kW/min.
U2-U1=Q-W
W=int p*dV
I guess what I really need is some clarification on the term "energy transferred in." Is this a rate of WORK?
Can anyone give me a hint before I go to bed? Then I can mull it over and attack this problem on the subway tomorrow! :smile:
