I need to learn about *real* gears
  • Thread starter Thread starter ChrisJA
    Gears
The discussion focuses on learning about the design and computation of real gears, emphasizing the need for understanding material properties, load factors, and gear dimensions to prevent failure. Key resources recommended include "Mechanical Engineering Design" by Shigley, the "Standard Handbook for Mechanical Engineers," and the "Tool & Manufacturing Engineers Handbook," which provide foundational knowledge on gear mechanics. Participants highlight the importance of cantilever analysis in understanding gear tooth strength and deflection under load. Additional online resources, such as KHK gears and NASA publications, are suggested for further technical insights. The goal is to create efficient, lightweight gears with a reasonable service life while making informed engineering trade-offs.
ChrisJA
I am interested in the design of real gears. I know much of the theory as covered in "physics 101."
Here is an example of the things I want to learn to compute: Given a gear made of some specific material and a given face width with say Module 1.0 tooth size how much tangential force can be applied before the gear fails? What is an industry accepted load (or safety) factor?
Or re-worded I ask it this way: how big must I make a gear so that it will not "strip out".
Yes I know it is a complicated subject and a single formula is not going to cover everything. What i need is a pointer to some educational material. Is there a beginner mechanical engineering text e-book on-line? My goal is to make the smallest and lightest gears that will do a given job with reasonable service life. I need to learn to make the required engineering trade offs.
Thanks.
Chris
The first place I'd go is "Mechanical Engineering Design" by Shigley. There are about 10 editions, with various coauthors. Of course there's a lot of other good stuff in there too.
Likes billy_joule
You might also check the Standard Handbook for Mechanical Engineers. Gears are discussed in chapter 8.
Alternatively, there is the Tool & Manufacturing Engineers Handbook. Gears are discussed in chapter 11.
Think of a gear tooth as a cantilever. The thickness of the tooth and the presence of undercutting determine the cross section of the tooth (cantilever structure). Both tooth contact angle and the number of teeth on a gearwheel control the degree of undercutting.
When a sudden force is applied to a tooth face, there will be a deflection. That may bring an adjacent tooth pair into contact and share the load, or it may be sufficient to break the tooth. It comes down to cantilever analysis.
Go to the KHK gear site. http://khkgears.net/gear-knowledge/
Download;
Gear Technical Reference. 13.8 MB. http://khkgears.net/wp-content/uploads/2015/10/gear_guide.pdf
The ABCs of Gears – A. 4.7 MB. http://khkgears.net/wp-content/uploads/2015/10/gearabc_a1.pdf
The ABCs of Gears – B. 7.2 MB. http://khkgears.net/wp-content/uploads/2015/10/gearabc_b.pdf
See also the Q & A about Gears. Plastic gears etc.
NASA Reference Publication 1152. Stress analysis starts on page 26.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19860005142.pdf
Take a look at; http://www.meshingwithgears.us/
The FAQ section has many useful links.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
