I want to design a diode circuit
The discussion focuses on designing a diode circuit to achieve specific voltage-output characteristics based on varying input voltages. Participants suggest that while it is possible to create the desired output using diodes, voltage sources, and resistors, the circuit may become complex. One user mentions the use of piecewise linear circuits and references a resource for further guidance. Another user successfully designs the circuit without zener diodes, opting for a combination of diodes and a voltage source instead. The conversation highlights the feasibility of the design while emphasizing the need for careful calculation of component values.
Nickclark
i want to design a diode circuit where the Vo vs. Vi looks like this:
Vi between -2 and 2 Vo = Vi
Vi between 2 and 4 Vo is a linear with slope 0.5
Vi between -2 and -4 Vo is a linear with slope 0.5
Vi>4 Vo=3
Vi<4 Vo=-3
how can i do this?
Just with diodes? Are you sure this is possible?
With a lot of transistors and resistors? That is possible, but it could look messy.
you can use diodes, voltage sources, and resistors.
i don't know how to get Vo=3 if Vi=4 and Vo=-3 if Vi=4 in one circuit!
This takes me back to generating arbitrary laws with 'piecewise linear' circuits using zener diodes and resistors. I googled the term and saw this link, which does the sort of thing I think you are after. (about half way through the slide show). Google the same term and you should get some other suggestions.
You'd have to work out the resistors for yourself but you should be able to solve the problem that way.
That's exactly what i was looking for! Thank you!
I solved it without zener, but used diode and a voltage source instead, hopefully it's correct!
Thanks again!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
