I want to know the explanation of this problem
The discussion centers on calculating the pressure difference in a cylindrical jet of water due to surface tension. The initial formula presented, ΔP = σ/r, was questioned, with a suggestion that it should be ΔP = 2σ/r instead. However, the participant later acknowledged a misunderstanding and confirmed the correct application of the formula. The surface tension of water is given as 0.0718 N/m, and the diameter of the jet is 4mm. The conversation highlights the importance of understanding the principles behind fluid dynamics and surface tension in pressure calculations.
Amr719
By How much does the pressure in a cylinderical jet of water 4mm in diameter exceed the pressure of the surrounding atmosphere if the surface tension of water is 0.0718 N/M?
ΔP= σ/r=0.0718/2*10^-3 , This is the answer I have but I don't understand from where did he get this law . Isn't it supposed to be ΔP= 2σ/r instead ?[/B]
On what basis do you feel it should be ΔP= 2σ/r?
Chet
Chet
Sorry I was wrong , I understand it now
