I was wondering something about diffraction
  • Level: Undergrad
  • Thread starter Byrgg
    Diffraction
86 replies · 12K views · last reply
Byrgg said:
Won't the phase of A and D end up being the same at the central maxima though? They bothe travel the same distance, and since they start wwith the same phase, shouldn't they end up with the same phase?
Sure.
Also, for the equation for calculating phase difference, I tried to figure out the reasoning behind the equation, and I came up with the following:
By dividing the path difference by the wavelength, you get how many wavelengths fit into the path difference. Multiplying by 360 degrees is simply for conversion into phase difference, for each wavelength that fits into the path difference, there will be a full cycle of 360 degrees. Does this sound right? Did I miss anything?
That's all there is to it.
Howver, one thing that I had trouble figuring out with this equation, is the reasoning behind doing thi in the opposite way, first multiplying by 360 degrees, and then dividing by the wavelength, and I couldn't come up with anything reasonable, I couldn't figure out these questions: Why do you multpliy by 360 degrees right away? And what do you do with these strange units you get(path difference * 360 degrees gets you very strange units in the result that I didn't know how to work with, metre * degrees?)?
I have no idea what you are asking here. Are you asking whether you can first multiply by 360 degrees and then divide by the wavelength? Sure, why not?
Doc Al said:
Not at all. As I thought we've shown, to a very good approximation you will easily have a central maximum.
I know, but true constuctive interference would only result when all segments are in phase, right? So isn't a real life example of constructive intereference almost impossible to create, seeing as all if the segments of the light have to travel the same distance?
I understand that the numbers would work out to be the same, but how would you explain the reasoning(as I had done in my example) behind this? Of what importance is the value of the path difference multiplied by a single cycle(and what's witht he weird units you get, metre*degrees?)? And why would you choose to multiply by a single cycle right away? I understand the reasoning if you do the division first, but the reasoning behind doing the multiplication first is what I find confusing, as demonstrated by my questions about it.
If you are talking about PERFECT, 100% constructive interference from a single slit, then sure that's impossible. But so what? You must realize that constructive interference is a matter of degree, not an all or nothing affair. Perfectly ordinary slits give perfectly acceptable, very bright, central maxima due to a high degree of constructive interference.
I have no idea why you would multiply path difference (in meters) by 360 degrees and retain that number. Why would you want to do this? Seems pretty meaningless to me except as a step in calculating phase difference.
If the segments are even slightly out of phase, isn't it considered destructive interference? I thought that constructive interference only occurred if the two segments were perfectly in phase.
By the step in calculating phase difference, do you mean the step after dividing the path difference by the wavelength? If so, it seems I'm on the right track, because this is similar to what I was thinking, I could think of no real reasoning behind multplying by 360 degrees first, even though, mathematically, you can still do this.
If two segments are exactly in phase, you will have perfect constructive interference; if exactly out of phase (by 180 degrees), you will have perfect destructive interference. For other phase differences, you'll get something in between.
I know, but what is 'something in between'? Isn't is a partial amount of destructive interference(reduces the overall amplitude, but not entirely)?
Perhaps you think that the sum of two segments of light that are slightly out of phase has smaller amplitude than either of the two segments alone? Not true at all. The amplitude of the sum is not quite twice as big, but close.
So then at what point does this phase difference not cause in increase in amplitude, but rather a decrease? I know that at 180 degrees phase difference, they will completely cancel, but at what phase difference will they partially cancel?
Use the formula in post #49 in this thread, and let [itex]A_2 = A_1[/itex] to make the two initial waves the same amplitude. Either experiment with various values for the phase difference [itex]\delta[/itex], or do a bit of algebra to find the value of [itex]\delta[/itex] that makes [itex]A = A_1[/itex].
Ok, thanks for that info, but what about my other questions, could someone help me those please?
I was thinking about this a little more, and I thought, sure the path difference multiplied by 360 degrees doesn't seem to hold any significance, but couldn't the same be said for the path difference divided by the wavelength? I'm just trying to sort this out, I have a hard time trying to understand how one way makes sense, and the other doesn't.
Byrgg said:
... the path difference multiplied by 360 degrees doesn't seem to hold any significance, but couldn't the same be said for the path difference divided by the wavelength?
Path difference is just a distance. What matters (in this context) is the phase difference, which depends on the wavelength. Dividing path difference by wavelength is meaningful, as it gives you the phase difference in terms of the number of wavelengths. Multiplying by 360 degrees just converts the number of wavelengths to degrees.
That last step is optional: A phase difference can be equally well expressed as a number of wavelengths or a number of degrees.
That last part really helped, thanks. I think I see now, because the 360 degrees is just for conversion, right? And because you can express it as a number of wavelengths, you are technically already complete, right? And, even though it IS possible, mathematically, to mutliply by 360 first, there's really no reasoning in doing so, because the resulting product is a fairly meaningless number, right?
And also, you can't express the phase difference in terms of the path difference because it's dependent on the wavelength, like you said, right? It's just a distance, as you said earlier, and because it does not reflect the wavelength in any way, it alone, cannot be used to describe the phase difference, right?
This keeps bugging me, I don't know why, for some reason, I just can't get over the fact that there's no real point in multiplying the path difference by 360 degrees. It just seems so weird that you can mathematically do it, but there's no real explanation as to why.
Someone please help, I think that another example, similar to this one(preferably a simple one, I've only completed gr.11 physics), would be helpful.
Someone please help me with this? I can try clarifying what it is I'm wondering exactly, if it's necessary.
I think it's necessary. I, for one, have no idea what's troubling you.
Alright, I'll explain what I'm trying to figure out here.
Basically, I'm confused about the reasoning behind doing the calculation for phase difference in ways that don't seem to make sense, but they do, in fact, mathematically work out to be correct.
The equation: phase difference = 360 degrees * path difference/wavelength, comes about from phase difference being able to be expressed as a number of wavelengths, or a certain number of degrees.
Earlier in this thread, something was said, similar to the following: The path difference divided by the wavelength gives the number of wavelengths that will fit into the path difference, and multiplying by 360 degrees is just a way to convert the number of wavelengths to to degrees(since 1 wavelength = 360 degrees).
As I said earlier in the post, what's confusing me, something that's been discussed a bit before in this thread, is the reasoning behind doing the calculation another way. I originally figured out that, mathematically, it's possible to first multiply the path difference by 360 degrees, and then divide by the wavelength, and achieve the same answer as you would if you did it the normal way, which is to divide the path difference by the wavelength, and then multiply by 360 degrees. More recently, I have also figured out that it would be possible to divide 360 degrees by the wavelength, and then multiply by the path difference, which, again, results in the same answer you would achieve from doing this the normal way.
I understand that these other two methods are mathematically possible, but I'm having trouble trying to figure out the reasoning behind these methods. As said earlier, in the normal way to do this, you start by getting the number of wavelengths which fit into the path difference, this is one way to express the phase difference, and is thus a meaningful number. However, the other methods you can take, involve steps which do not seem as logical, the result of the path difference, multiplied by 360 degrees, while possible to do mathematically, does not seem to bear any relevance when taken at face value, nor does 360 degrees divided by the wavelength, which is like the other value, mathematically possible to do.
I'm having trouble understanding how it is exactly, that these numbers are irrelevant, one of my early impressions was that, the units you get when you carry out these steps do not seem to make any sense, 360 degrees multplied by the path difference gets you a number which is units of degrees*metres(or any other valid unit that can be used to measure distance). 360 degrees divided by the wavelength, also gets you strange units(different from the previously mentioned strange units) of degrees/metres(or any other valid unit that can be used to measure distance). One thing that I thought, was that these strange units may be reason enough to claim the steps that get them to be nonsensical, though I'm not sure if it correct to say so, and so this is one source of my confusion. I also thought that there may still be other reasons for these steps to not seem relevant.
One other reason that I thought these steps did not seem to bear relevance, was that 360 degrees seems only to be the conversion factor to multiply a number of wavelengths by(similar to 100 centimetres being the value which you multiply metres by, in order to convert metres to centimetres), being nothing but a conversion factor to turn a number of wavelengths into degrees, I figured it was meaningless to multiply this number by the path difference, or divide it by the wavelength. However, I don't know if it is correct to assume that 360 degrees is only the conversion factor used to convert a number of wavelengths to a number of degrees, another source of confusion.
Despite my reasons for thinking these steps were meaningless, though mathematically valid, I thought that if someone had great enough knowledge about wavelengths, and how they relate to degrees and such, should be able to use their knowledge as reasoning for these steps. However, I thought that, despite someone having this knowledge, my other reasons may still stand, and so in order to say you can take these steps, you would have to have knowledge of the normal way to do the equation. This is my main source of confusion, would it be accurate to say that someone with enough knowledge on the subject could take these steps, which seem nonsensical, when taken at face value, or would they not be able to provide reasoning for these steps at all, without having knowledge of the normal way to do the equation?
I know there's a lot there, but if someone could help me figure out these questions, I'd be greatful.
I'm still not quite zeroing in on your confusion, but here are some ideas.
What matters is expressing the path difference in terms of wavelengths. To do that, you need to know the wavelength. In a sense, that first step can be viewed as a conversion--from meters to wavelengths. Here's an example:
Let 1 wavelength = 600 nm (= 600 x 10^-9 m)
Let the path difference = 400 nm
So:
path difference = 400 nm * ( 1 wavelength/ 600 nm) = 2/3 wavelengths
Now a number of wavelengths can be expressed as a phase difference, since 1 wavelength = 360 degrees. (That's all there is to that.) So, putting it all together we get:
Phase difference = 400 nm * ( 1 wavelength/ 600 nm) * (360 degrees/ 1 wavelength) = 240 degrees
That's how you find the phase difference in degrees. I think you understand that. I think your question is "Is there some secret significance to multiplying all the numerators together first, then dividing by the denominators?" Like this:
Phase difference = [400 nm * 1 wavelength * 360 degrees]/[600 nm * 1 wavelength] = 240 degrees
Does [400 nm * 1 wavelength * 360 degrees] have some special meaning? Not to me!
Why did you multiply by (1 wavelength/600nm)? I thought you only divided by the wavelength, which, in this case, is 600nm. Does have something to do with unit conversions?
Why did you multiply the path differece(400 nm) by 360 degrees and one wavelength? Why do you multiply by one wavelength? If it's conversion related, wouldn't you multiply by (360 degrees/1 wavelength) instead of (360 degrees*1 wavelength)? Or am I missing something?
It seems logical to say that this value does not have any relevance or special meaning, but I find it strange how something that can be mathematically, does not have any real explanation or reasoning behind it. This is where my points of of confusion came up, I'll summarize them again here, and maybe someone could help me figure them out.
One source of confusion is the strange units that you'll get when you multiply 360 degrees by the path difference, assuming you measured the path difference in metres, here, you would get units of degrees*metres. The same goes for dividing 360 degrees by wavelength, which is possible to do mathematically, but, assuming you measured the path difference in metres, results in units degrees/metres.
In any equation I've learned, the units always seem to make sense in one way or another, though, I can't think of any reason why a number in the units of degrees*metres, or degrees/metres would be useful. Here, the confusion arises from not knowing whether or not these are useful units, and if they aren't useful units, is this reason enough to dismiss these steps as nonsensical?
Another source of confusion relates to the purpose of the 360 degrees. Is it correct to say that this number is only a conversion factor, which when multiplied by a number of wavelengths, gets you the number of wavelengths as a number in degrees? If this is only a conversion factor for a number of wavelengths, is this also reason enough to dismiss these steps as nonsensical?
My final source of confusion is, would a person with great enough knowledge on the subject be able to use their knowledge as reasoning to first take one of these seemingly nonsenical steps? Or, would you assume, that, in order for anyone-- no matter how great their knowledge-- to take these steps, they would have to have knowledge of the normal way to do the equation?
I hope that explained exactly what's confusing me a little better. I can try to explain it a bit more, if no one really understands what it is I'm having trouble with here.
